[SOLVED] failure to program flash on STM32F407
  • [SOLVED] failure to program flash on STM32F407
    Hi
    I notice that others are also having problems with St micros and flash programming, but my brand new jlink won't flash at all
    Im following this page from the manufacturers website segger.com/products/debug-prob…lash-download/#tab-3145-4
    The output from JLinkExe is shown at the bottom.
    Im using linux and the program binary will download OK but will not program the flash, no errors shown, and the flash is still blank
    I can use an olimex usb-ocd-h and the flash can be programmed correctly
    According to the Segger website "Supports direct download into RAM and flash memory"
    If I program the flash with the olimex, then I can debug with the Jlink, so connections and power must be OK
    I have now tried arm_segger_embedded_studio_334_linux_x64 which can program the flash under linux, which suggests the problem is JLinkExe.
    Which may sound like a solution, but Im trying to use eclipse which cannot program the flash through jlink either
    Does anybody have any suggestion about what the problem might be ?
    Thanks in advance Chris
    --- JLinkExe output when trying to program flash at 0x8000000 ----
    user@linux:~/eclipse> ./JLink_Linux_V622d_x86_64/JLinkExe -if swd -device cortex-m4 -speed 4000
    SEGGER J-Link Commander V6.22d (Compiled Dec 14 2017 18:34:26)
    DLL version V6.22d, compiled Dec 14 2017 18:34:21
    Firmware: J-Link V10 compiled Dec 12 2017 16:37:47
    Hardware version: V10.10
    S/N: 260104775
    License(s): FlashBP, GDB
    OEM: SEGGER-EDU
    VTref = 4.902V
    J-Link>loadbin /home/user/sandpit/st_micro/stm32f1_work/Project/IOToggle/main.hex 0x8000000
    Target connection not established yet but required for command.
    Device "CORTEX-M4" selected.
    Connecting to target via SWD
    AP[0]: Core found
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    Cortex-M4 identified.
    Downloading file [/home/user/sandpit/st_micro/stm32f1_work/Project/IOToggle/main.hex]...
    O.K.
    The post was edited 3 times, last by strangerover2002 ().
    Are you programming an eval board or custom hardware?
    You are not following the instructions on the web page as written.
    First you need to select the exact STM32F407 device that you are using.
    In the output you provided you are simply choosing a generic "CORTEX-M4" device.
    This way flash download will not work as J-Link does not know where the flash is located for that device.
    Pass the commander the exact device name and you should be good to go.
    One more thing that looks suspicious. The Commander outputs a VTref of 4.9 V.
    This seems rather high for this particular target device (typically 3.3 V). Make sure that the board you are using is capable of handling the ~5 V.
    Because this voltage will be applied to the SWD pins and if there is no buffer stage on your board between J-Link and the STM32F407 your target device will most likely be damaged.
  • Hi Nino
    typing "device ?" should give a list of devices but it doesn't
    so I had to rely on the segger webpage which gave me generic devices,
    i have now found another page with the specific devices
    using device = stm32f407vg works fine.
    thanks for your help
    Chris
