Notification from SWIPELIST
  • Notification from SWIPELIST
    I'm trying to catch WM_NOTIFICATION_RELEASED and WM_NOTIFICATION_SEL_CHANGED
    from SWIPELIST widget, but failing. I can get WM_NOTIFICAITON_CLICKED message
    when I press a item in the SWIPELIST.
    I can see that bgcolor changed blue to black when I move or release my finger on the screen,
    so it looks de-select the item is working, but I'm not able to receive WM_NOTIFICATION_RELEASED
    /WM_NOTIFICATION_SEL_CHANGED on the parent window.
    Is there any clue to enable those two notifications on the SWIPELIST?
    I'm using STemWin 5.40.
    Tosh
    Attached is a short example on how to react on the swipelist notifications.
    The WM_NOTIFICATION_SEL_CHANGED doesn't realy makes sense so I left it out. If you want to react on it simply add another case to the callback function.
    WM_NOTIFICATION_SEL_CHANGED gets only send if the pointer input (or touch) leaves the selected item.
