[SOLVED] OZONE load variables when loading project
    This is already possible.
    It is explained in detail in the user manual in the section "Window Actions".
    Alternatively you can simply do a manual ad to watch as usual in your running session.
    Then you should see the necessary commands printed in the Console window.
    In this case it would be:
    Window.Add ("Watched Data", "Var");
    Window.Show ("Watched Data");
    which you can add in the Ozone project .jdebug file in the function OnProjectLoad()
    Great to hear that everything is working as expected now.
    This thread will be closed and marked as solved now.
