How to make sure an image is removed from screen?
  • How to make sure an image is removed from screen?
    Hello all,
    I wrote some code as follows:
    1. static void _cbImageShtr(WM_MESSAGE * pMsg) {
    2. /* Local variable(s) */
    3. WM_HWIN hWin;
    4. uint8_t UserData[20];
    5. uint8_t * pData;
    6. int Index;
    7. int NumItems;
    8. int Period;
    9. size_t Offset;
    10. /* Handle the message(s) needed */
    11. switch (pMsg->MsgId) {
    12. case WM_TIMER:
    13. hWin = pMsg->hWin;
    14. if (IMAGE_GetUserData(hWin, UserData, sizeof(UserData))) {
    15. pData = UserData;
    16. Offset = sizeof(int);
    17. Period = *(int *)pData;
    18. pData += Offset;
    19. NumItems = *(int *)pData;
    20. pData += Offset;
    21. Index = *(int *)pData + 1;
    22. if (Index < NumItems) {
    23. *(int *)pData = Index;
    24. pData += Offset;
    25. IMAGE_SetBitmap(hWin, ((void **)*((intptr_t *)pData))[Index]);
    26. IMAGE_SetUserData(hWin, UserData, sizeof(UserData));
    27. WM_RestartTimer(pMsg->Data.v, Period);
    28. } else {
    29. WM_DeleteTimer(pMsg->Data.v);
    30. WM_HideWindow(hWin);
    31. WM_DeleteWindow(hWin);
    32. }
    33. }
    34. return;
    35. case WM_DELETE:
    36. _hImageShtr = WM_HMEM_NULL;
    37. WM_SendMessageNoPara(_hColorbar, UI_MSG_SCREEN_DUMP);
    38. break;
    39. }
    40. /* Default message handler */
    41. IMAGE_Callback(pMsg);
    42. }
    It will display a serial of images, then tell emWin to get a screenshot.
    The problem is that, sometimes the last image showed in the screenshot.
    But, look into the code, this should not happen, right? For it's hidden then deleted:
    1. WM_HideWindow(hWin);
    2. WM_DeleteWindow(hWin);
    So, the question is, how to make sure that an image is removed from screen?
    PS:
    I get a screenshot by copy the visible buffer of emWin, not using BMP_Serialize() for its speed.
