[SOLVED] Start application for empty SAMG55 devices in production environment
  • [SOLVED] Start application for empty SAMG55 devices in production environment
    I'm trying to flash 2 daisy chained SAMG55 chips using J-Flash.
    For an empty chip, I will have to manually start application in J-Flash after programming the chip. I need to program the chips in production environment and I'm using a batch file to automate the process. I have tried the following:
    1. In J-Flash project settings, check 'start application' (tried both SFR and reset pin)
    2. Add -startapp command in the batch file so my script looks like this:
    start /min "J-Flash" "C:\Program Files (x86)\SEGGER\JLink_V620c\jFlash.exe" -openprjProjectFile.jflash -openData.hex -auto -startapp -exit
    But none seems to work reliably. The only way to ensure an empty chip gets fired and booted up is to do it manually through JFlash.exe
    Another error I recently encountered is that the '-exit' command causes JFlash.exe to stop working.. I have tried to re-install but the issue persists.
    Please advise.
    The post was edited 1 time, last by shurui ().
    Is the reset pin connected to the debug interface and target device?
    What are the exact steps you do when it is "working"?
    Could you try to install the latest J-Link software version and see if the issue persists?
  • Hi Nino,
    Yes, the reset pin is connected correctly. Even a power-cycle wouldn't bring the unit up.
    What I do to make it work is that:
    step 1. Program the unit -- either through the command line or the JFlash GUI interface. The command I use is:
    step 2. Start application in JFlash -- Go to JFlash GUI interface -> manual programming -> start application (F9). This will ensure to fire up the chip properly.
    I have upgraded to latest version 6.22a still with no luck.
    I added a delay of 500ms in the exit steps but I don't have any brand new boards to try on right now.
  • This morning I tried the following on one board:
    Added a delay of 500ms in the exit steps, ran it using the command:
    start /min "J-Flash" "C:\Program Files (x86)\SEGGER\JLink_V622a\jFlash.exe" -openprjProjectFile.jflash -openData.hex -auto -startapp -exit
    It did not start the chip up.
    I then increased the delay to 1000ms, and also checked start application via reset pin, and ran the command again. This time the chip was fired up correctly. Since I did two changes at the same time, I'm not sure which one is the fix or am I just getting it out of pure luck. I don't have enough brand new boards for me to test out now, but should have some in tomorrow and will be able to try it on a couple more empty chips.
    Also the last issue I described (JFlash freezes on command -exit) still persists after I updated to 622a. But it only appears if I try to bring up the JFlash GUI window while I specify in the command to do it minimized.
  • I still could not get an empty chip to start up reliably. Sometimes one method works, sometimes it doesn't. Sometimes it works on this one, and doesn't work on the other one.
    The only reliable way is to go to J-flash, do manual production-erase chip, manual production-programverify, manual production-start app.
    I've also tried to break the command statement into 3 pieces, first one -erasechip, 2nd -programverify, 3rd -startapp. And it *sometimes* would work on *some* chips.
    I don't know what to try next...
    Are you talking about the programed target device?
    If so then this whole issue seems to be related to the application you are trying to program into the target.
    When doing a power on reset the application should always start running...
    If it does not the programmed application is broken in some way.
    Try to debug the application and find out why it is not starting in the first place.
    If the application does not run on its own the J-Link can't do much here.
    My guess would be that the increased delay helps here.
    Does the Reset line have some capacitor or similar attached so the Reset pin can't toggle immediately?
    Make sure that there are no additional parts attached on the reset signal that might alter the timing behaviour of the reset signal.
