embOS with Renesas SH-2A SH7670 in HEW
    I am using embOS for SH2A and HEW and it works w/o any problem like embOS for any other cpu I used before.
    I also tested many other OS for SH2A but I decided to use embOS again because I like that embOS is available on many cpus, so it is very easy to port an application to another cpu.
    You should download the embOS trial version for SH2A and HEW, then you could check out by yourself if you feel comfortable with embOS, a BSP for SH2A7670 is included (I use the same cpu).
    --Daniel
