[SOLVED] Connecting J-Link via USB within ARM DS-5 IDE
  • [SOLVED] Connecting J-Link via USB within ARM DS-5 IDE
    I am using NXP iMX7 Sabre evaluation board, and am trying to create a debug session via J-Link Base probe, connected to the JTAG port of the board.
    When I am using the command line interface from Segger it works fine, I can connect and perform all command line commands.
    But trying to connect from within the WINDOWS ARM DS-5 environment, I cannot find the USB connection under Debug Configuration->CONNECTION.
    Looking at the BROWSE option it is empty.
    Looking at the Device manager I can see the j-Link Driver, so I assume it is configured fine.
    Can anyone assist here?
    To connect with DS-5 to J-Link you will need a J-Link Plus or higher model that includes the RDI/RDDI feature.
    More information can be found here: segger.com/products/debug-prob…technology/ides/arm-ds-5/
    Currently J-link with DS-5 works only under Windows.
    Linux support is not planned at the moment.
