Hello all,
I am using Version V3.03.01 uCos_III within a LPC2925 ARM9 processor.
The debugging pod is a J-link base version 9.2. I used the
sample code for uCos_III from your website. I have added the code to the build.
communications write to IR: Expected 0x1, got 0x0 Trap Command : 2 @ off
0x9". Other times I just get RTT block not found. I am not sure how to
proceed from here.
I have read the manual several times, but I still can't seem to get
communication between my version of uCos_III and SystemView. I know the
later version of uCos III release in 2016 has already integrated
SystemView in their cod base, but I am using a 2012 release.
Can you give me more informaiton on how the communicaiton flow between
the SystemView Host program an the target? From what I understand,
SystemView first looks for the string "SEGGER RTT" to find the
control block. What does SystemView do next?
- I check within RAM memory and
found "SEGGER RTT" string marking the being of the RTT control block at a
memory location of 0x8000222c. SystemView should be able to find the
control block, but doesn't
proceed from here.
The post was edited 2 times, last by edavis@rexa.com ().
