[SOLVED] Flasher 5 target program erased when powered OFF
  • [SOLVED] Flasher 5 target program erased when powered OFF
    I would like to use my Flasher 5 programmer on stand-alone mode, but it appears that the target program is erased when the programmer is powered Off.
    Are there some settings I missed to make it non-volatile or is this the standard behavior of the flasher ?
    Thanks and regards,
    Micaël
  • Hello Micaël,
    It looks like your Flasher 5 device has been damaged. The data file is stored to a non-volatile memory and should survive a power cycle.
    You can trade in your defective device under the conditions described here: segger.com/purchase/trade-in-program/
    Marius
