[SOLVED] SYSVIEW_RAM_BASE define
  • Hello Mykhaylo,
    From the SystemView manual:
    SEGGER_SYSVIEW_ID_BASE is subtracted from a pointer to get its ID. It can be set to
    subtract the base RAM address from pointers, which still results in unique, but smaller IDs.
    For example if the RAM range is 0x20000000 to 0x20001000 it is recommended to define
    SEGGER_SYSVIEW_ID_BASE as 0x20000000 , which results in the pointer 0x20000100 to have
    the ID 0x100 and requires two instead of four bits to store it.
