[SOLVED] SystemView In No OS mode in CCS for Tiva
  • [SOLVED] SystemView In No OS mode in CCS for Tiva
    I use Code Composer Studio
    Version: 7.1.0.00016
    MicroController - TM4C129 (Tiva series)
    J-Link Ultra+ - debugger
    I am experimenting with SystemView in No OS mode....
    i am using evaluation module
    DK-TM4C129X
    Now i added SystemView files to the project....But when i try to build the project i encounter error ......
    What is the right way to proceed... How to get systemView work for CCS projects for CortexM4....
    Unresolved symbol OS_GetBASEPRI and OS_SetBASEPRI
    #define SEGGER_RTT_LOCK() { \
    unsigned int LockState; \
    LockState = OS_GetBASEPRI(); \
    OS_SetBASEPRI(SEGGER_RTT_MAX_INTERRUPT_PRIORITY);
    #define SEGGER_RTT_UNLOCK() OS_SetBASEPRI(LockState);
    SystemView has only been used with CCS in combination with embOS, therefore the default combination used the embOS locking mechanism.
    Replacing it with a definition like this should work:
    2. #elif (defined (__TI_ARM_V7M3__) || defined (__TI_ARM_V7M4__))
    3. #ifndef SEGGER_RTT_MAX_INTERRUPT_PRIORITY
    4. #define SEGGER_RTT_MAX_INTERRUPT_PRIORITY (0x20)
    5. #endif
    6. #define SEGGER_RTT_LOCK() { \
    7. unsigned int LockState; \
    8. LockState = _set_interrupt_priority(SEGGER_RTT_MAX_INTERRUPT_PRIORITY);
    9. #define SEGGER_RTT_UNLOCK() _set_interrupt_priority(LockState); \
    10. }
    11. #endif
    12. ...
    Johannes
