[SOLVED] How to execute and debug code from RAM when using SES 3 and Cortex-M MCU
  • [SOLVED] How to execute and debug code from RAM when using SES 3 and Cortex-M MCU
    Hi, I'm Matthew. I use
    - 64-bit SES 3.26 on 64-bit Windows 10
    - J-Link Plus or onboard J-Link (Nordic's dev kits have a J-Link on the board itself)
    - J-Link 6.16h
    - Nordic's PCA10040 v1.1.1 board (this board uses nRF52832-QFAA MCU)
    - STM32F4 Discovery board
    - SEGGER RTT Viewer
    I have noticed an interesting topic; execute code from RAM.
    - Nordic, How to execute code from RAM on nRF51 with Keil MDK
    - IAR EWARM, Download and run whole application in RAM (Cortex-M3)
    - IAR Keyword, __ramfunc (page362);
    The __ramfunc keyword makes a function execute in RAM
    Since SES 3 uses GCC or Clang this might be a matter of configuring GCC or Clang.
    However, just to check, is it possible to execute and debug code from RAM when using SES 3 and Cortex-M MCU?
    If there are tutorials related to the link, it will be great if you provide some links.
    -Best Regards
    -Best Regards, Matthew
  • Hello Matthew,
    Thank you for you inquiry.
    Under Help->Contents search for "Linking and section placement"
    In that chapter it is described how to place functions into different sections e.g. RAM.
    You can also find the User Manual here.
