[SOLVED] Questions about Ozone
  • [SOLVED] Questions about Ozone
    I have a J-Link EDU and have installed Ozone for the first time. I am using CLion as my IDE and am starting Ozone from there using the following command:
    Ozone <myproject.jdebug>
    This works pretty well, however, I have a few questions:
    • Every time I want to initiate a new debug session I have to restart Ozone (which takes a few seconds). Is there a way to get the running instance of Ozone to reload the elf file without having to restart?
    • Each time load Ozone and hit connect I get a message saying "without a valid license....run in evaluation mode" and have to click OK to dismiss it, which is slowing down my workflow somewhat. How can I purchase a license? I searched the website but couldn't find any way of actually purchasing the software.
    Additionally, I get the following output when running Ozone from the command line:
    2017-10-01 21:56:20.898613+0100 Ozone[48151:5644842] WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.12.6. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
    Call location:
    2017-10-01 21:56:20.899045+0100 Ozone[48151:5644842] 0 CarbonCore 0x00007fff7ae171b1 ___Gestalt_SystemVersion_block_invoke + 121
    2017-10-01 21:56:20.899054+0100 Ozone[48151:5644842] 1 libdispatch.dylib 0x00007fff8f65f8fc _dispatch_client_callout + 8
    2017-10-01 21:56:20.899073+0100 Ozone[48151:5644842] 2 libdispatch.dylib 0x00007fff8f65f8b9 dispatch_once_f + 38
    2017-10-01 21:56:20.899078+0100 Ozone[48151:5644842] 3 CarbonCore 0x00007fff7ada5292 _Gestalt_SystemVersion + 976
    2017-10-01 21:56:20.899096+0100 Ozone[48151:5644842] 4 CarbonCore 0x00007fff7ada4aad Gestalt + 139
    2017-10-01 21:56:20.899101+0100 Ozone[48151:5644842] 5 libQtCore.4.8.6.dylib 0x0000000105125fb6 _GLOBAL__I__Z8qVersionv + 22
    2017-10-01 21:56:20.899105+0100 Ozone[48151:5644842] 6 ??? 0x000000010e1f0a1b 0x0 + 4531882523
    Additional licenses are not a available for J-Link EDU.
    Additional licenses are only available for J-Link BASE.
    The Ozone license is included in the RDI / RDDI license, which currently is 198€ (point 8.08.03 on the price list)
    J-Link PLUS or higher come with all additional licenses included.
    Since J-Link BASE + a Ozone license add up to a price equal to the J-Link PLUS, I would recommend buying a J-Link PLUS, since it comes with all additional licenses free of charge, like unlimited flash breakpoints.
    Please note that the J-Link EDU can only be used for evaluation purposes (if not used for university / hobbyist use cases).
    Regarding your other questions: I forwarded this thread to our Ozone expert. :)
  • Hello Don,
    I don't quite understand why you need to restart Ozone each time in your case. Can't you simply stop the debug session (red On/Off icon in the top right corner of Ozone) and restart it again?
    Could you post a screenshot of your open Ozone debug session?
    What OS are you using currently? Does it run in a VM or natively?
    With what parameters do you call Ozone?
  • So I figured out that if I just rebuild my .elf file from within CLion rather than re-initiating a debug session Ozone automatically detects this and prompts me to reload it - no need to restart - great!
    I am using OSX 10.12.6 on a 2016 Macbook Pro. Ozone is running natively.
    Here's the parameters I use to call Ozone:
    Ozone.app /Users/donturner/PCode/workspace-kinetis/blinky/blinky.jdebug
  • Hello Don,
    Great to hear that it is working for you now as expected.
    The error messages that you are seeing when starting Ozone through a commandline are QT internal errors.
    As a workaround it might work to call Ozone with a differente GUI-theme that does not produce these errors under OSX.
    Could you try the following options?
    Ozone --style Plastique or
    Ozone --style Windows or
    Ozone --style CleanLooks
    Does one of these solve the issue?
  • I had to add an '=' to get the different styles to work:
    Ozone --style=Plastique
    however, I still got the Qt warnings from CLion. Interestingly if I launch Ozone from the terminal I do not see these warnings, although that may just be because the terminal doesn't show warnings by default.
    It's not stopping me from using Ozone I just thought you should know - the warning seems to from libQtCore, maybe building against a newer version of OSX SDK would fix it, as per: bugreports.qt.io/browse/QTBUG-46162
  • Hello Don,
    Sorry, mistake on my end when copy pasting the commands.
    I will forward this to our Ozone developer and see if this issue can be fixed in a future version of Ozone without updating qt.
