STM32 with SSD1963
  • STM32 with SSD1963
    i'm new and i try to understand the samples from emWin.
    But i understand not the connections between MCU and grafic controller.
    I found in the user manual the different possibility to connect the controller.
    In the case of the online sample i can't say which controller and which mode is used.
    My goal is to connect the SSD1963 controller to a STM32 board.
    For the SSD1963 i think the indirect interface is the correct one.
    33.2.2 Indirect interface - Parallel bus
    Maybe someone can get me a short tip.
    Bernhard
    The SSD1963 LCD controller is supported by the GUIDRV_FlexColor driver.
    It gets connected by an indirect interface.
    Attached is a sample configuration for the GUIDRV_FlexColor configured to be used for the SSD1963. This configuration uses bit banging but it should be quite easy to use a hardware interface like SPI.
