Is PrepareFW tool in EMLOAD can be used to combine hex/binaries?
  • Hi Pratheesh,
    The PrepareFW tool is designed to read in a single file only. However this file may contain several memory regions with gaps.
    These gaps will be preserved as gaps if they are big enough (more than a couple of bytes) to avoid an unnecessary region overhead in the output.
    To combine multiple files you can easily use J-Flash from our J-Link Software and Documentation Pack, available for download from here:
    segger.com/downloads/jlink/
    J-Flash can even be be used via command line arguments to combine multiple files. The same applies as for PrepareFW, this is only possible if addresses from the files to merge do not overlap.
    Oliver
