Using JLink with Keil uVision version 5.24
  • Using JLink with Keil uVision version 5.24
    Hello All,
    I have a J-Link Ultra+; trying to debug an RTX app w/Keil - and at the very beginning it jumps to a bad address - a DCD 'table'.
    The target is an ST32F4xxx.
    If I use the ST-Link - this does not happen.
    I have been able to do the configuration where I can attach to a running target - that works - but none of the RTX plug-ins seem to get recognized when I do that.
    I just downloaded version 6.18c and am using that.
    I noticed a note on the Keil site to use the RDI I/F with JLink; I'm attached; but haven't confirmed if RDI is the mode of operation as of yet.
    I've been able to attach with SW or JTAG with the same result - I prefer JTAG since we have that fully pinned out.
    The flash download from the Keil uVsion IDE works just fine; even hits reset and starts the app after it is downloaded.
    John W.
  • Hello Again,
    With the Ultra+; I'm hitting the hard fault handler as soon as I jump from the reset vector.
    Maybe this is a known issue; or I've got something wrong. I do have the hard fault handler coded; but it is showing up as:
    0x08002cc0 FFFFFFFF DCD 0xFFFFFFFF
    which isn't right either for some reason.
    John W.
  • Hello Again,
    I'm occasionally getting a message about the Jlink not being able to drive NRST low when it makes a connection to the target; I see this sometimes too just running the standalone flasher.
    I'm not seeing it all the time; and I've checked that signal to make sure it isn't being driven hard; so, how strong can the JLink drive the NRST JTAG signal? I know it's probably in the datasheet; but I've seen
    this pop up with the Keil tools - and I didn't even know this was an issue until I got the JLink settings correct.
    Any insight; other than 'check the boards' NRST signal' - which I've already done, appreciated.
    John W.
  • Hi John,
    could you please provide us with a screenshot of the error?
    Could you estimate how often? 1 out of 5, 10, 20, 100, ...
  • Hello Niklas,
    I'd say, on certain boards - 1 out of 2. I do have boards that I've done bring-up on and don't see it at all. Reset circuit is the same; or at least should be.
    Screen shots attached.
    John
  • Helo,
    I have a very similar Problem with Keil 5.24, J-Link and a NXP 1788 Eval board.
    I'm using the (unchanged) sample project provided for Keil by Segger (Start\BoardSupport\NXP\LPC1788_EA)
    The code vom compiles, is written to flash and runs after a reset.
    But if I try to connect to the target via the debugger, it does not show the sourcecode. Only the disassembly view works.
    Here is the log of the J-Link connecting to the target:
    Target info:
    Device: LPC1788
    VTarget = 3.248V
    State of Pins: TCK: 1, TDI: 0, TDO: 0, TMS: 0, TRES: 1, TRST: 1
    Hardware-Breakpoints: 6
    Software-Breakpoints: 8192
    Watchpoints: 4
    JTAG speed: 4800 kHz
    Load "C:\\develop\\embostrial_new\\Start\\BoardSupport\\NXP\\LPC1788_EA\\Output\\Debug\\Start_LPC1788_EA_CMSIS.axf"
    *** error 57: illegal address (0x00001000)
    * JLink Info: J-Link: Flash download: Bank 0 @ 0x00000000: 1 range affected (4096 bytes)
    * JLink Info: J-Link: Flash download: Total time needed: 0.262s (Prepare: 0.078s, Compare: 0.023s, Erase: 0.111s, Program: 0.042s, Verify: 0.000s, Restore: 0.005s)
    * JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    * JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
    I have no idea where the "illegal address" error comes from.
    It's no Hardware problem, as I have tried it with a J-Trace als well, showing the same problem.
    I have also tried J-Link Driver versions 6.16c, 6.18c and 6.19d: makes no difference.
    Using JTAG or SWD: makes no difference.
    Using ETM trace (with J-Trace): makes no difference.
    The same sample project, but for EmbeddedStudio 3.24 runs/flashes well and can be debugged from ES
    without any problem.
    Any ideas ? (besides buying an ULINK ;( )
    regards
