[SOLVED] [Ozone] Possibility to load symbols from multiple .ELF files?
  • [SOLVED] [Ozone] Possibility to load symbols from multiple .ELF files?
    Is it possible to load symbols from multiple .ELF files in Ozone, and how?
    I have a bootloader + application that I would like to have symbols for, at the same time.
    (in GDB this is possible using "add-symbol-file")
    Maxime
    The post was edited 1 time, last by maximevince ().
  • Hello Maxime,
    Unfortunately Ozone currently does not support loading multiple .elf files simultaneously, only consecutively.
    But our IDE Embedded Studio does which can be used for free for evaluation purposes with our J-Links.
    More information can be found here or in the Embedded Studio manual.
  • You are welcome.
    I will consider this thread as solved.
