Programming QSPI flash on Zynq ZC702 eval board - JLink Plus
  • Programming QSPI flash on Zynq ZC702 eval board - JLink Plus
    I'm currently trying to use a J-Link Plus to program the QSPI flash on the Xilinx ZC702 board.
    Using JFlash I've selected Zynq 7020 as the device and can connect to the target successfully.
    However if I attempt to program the flash then errors are reported as follows:-
    Programming target (255 bytes, 1 range) ...
    - Start of determining flash info (Bank 0 @ 0xFC000000)
    - ERROR: Timeout while checking target RAM, core does not stop. (PC = 0x00000004, CPSR = 0x0000019B, LR = 0x00000014)!
    - ERROR: Failed to prepare for programming.
    Failed to execute RAMCode for RAM check!
    - Error while determining flash info (Bank 0 @ 0xFC000000)
    - End of determining flash info
    - Flash bank info:
    - 1 * 16384 KB @ 0xFC000000
    - ERROR: Failed to program target
    This was generating 255 bytes of test data and then trying to program using the "Manual Programming" option.
    Also fails when trying to use JLink commander to program.
    What steps an I missing in order to program successfully?
    Although Zynq 7020 is listed as supported on the Segger website do I still need to manually add init steps to the JFlash project?
    JLink log and JFlash project are attached for reference.
    I'm successfully using the J-Link Plus for debugging over JTAG under Mentor Sourcery Codebench on the same target board.
    Thanks.
    • JLink.zip
      (26.4 kB, downloaded 539 times, last: )
    • zc702.jflash
      (1.59 kB, downloaded 700 times, last: )
    In the "MCU" tab of the J-Flash project settings, what RAM address & size is configured?
    Does it work if you reduce the amount of RAM used(e.g to 8 KB)?
  • Hi Niklas,
    Address is 0 and size is 256KB
    I tried reducing to 8KB but operation still failed although error messages were slightly different - see below
    - Flash bank info:
    - 255 bytes could not be programmed.
    - Target programmed successfully - Completed after 0.083 sec
    Despite last entry saying success.
    i just gave it a try on a Zync 7020 zedboard,
    but could not reproduce any issue after setting RAM to 8KB:
    1. Application log started
    2. - J-Flash V6.18 (J-Flash compiled Aug 3 2017 16:19:44)
    3. - JLinkARM.dll V6.18 (DLL compiled Aug 3 2017 16:19:24)
    4. Creating new project file [C:\Program Files (x86)\SEGGER\JLink_V618\Default.jflash] ...
    5. - New project created successfully
    6. Close project
    7. - Project closed
    8. Creating new project ...
    9. - New project created successfully
    10. Reading entire flash chip ...
    11. - Connecting ...
    12. - Connected successfully
    13. - 1 sector, 1 range, 0xFC000000 - 0xFCFFFFFF
    14. - Start of determining flash info (Bank 0 @ 0xFC000000)
    15. - End of determining flash info
    16. - Flash bank info:
    17. - 512 * 64 KB @ 0xFC000000
    18. - Start of preparing flash programming
    19. - End of preparing flash programming
    20. - Start of blank checking
    21. - End of blank checking
    22. - Start of blank checking
    23. - End of blank checking
    24. - Start of blank checking
    25. - End of blank checking
    26. - Start of blank checking
    27. - End of blank checking
    28. - Start of blank checking
    29. - End of blank checking
    30. - Start of blank checking
    31. - End of blank checking
    32. - Start of blank checking
    33. - End of blank checking
    34. - Start of blank checking
    35. - End of blank checking
    36. - Start of blank checking
    37. - End of blank checking
    38. - Start of blank checking
    39. - End of blank checking
    40. - Start of blank checking
    41. - End of blank checking
    42. - Start of blank checking
    43. - End of blank checking
    44. - Start of blank checking
    45. - End of blank checking
    46. - Start of blank checking
    47. - End of blank checking
    48. - Start of blank checking
    49. - End of blank checking
    50. - Start of blank checking
    51. - End of blank checking
    52. - Start of blank checking
    53. - End of blank checking
    54. - Start of blank checking
    55. - End of blank checking
    56. - Start of blank checking
    57. - End of blank checking
    58. - Start of blank checking
    59. - End of blank checking
    60. - Start of blank checking
    61. - End of blank checking
    62. - Start of blank checking
    63. - End of blank checking
    64. - Start of blank checking
    65. - End of blank checking
    66. - Start of blank checking
    67. - End of blank checking
    68. - Start of blank checking
    69. - End of blank checking
    70. - Start of blank checking
    71. - End of blank checking
    72. - Start of blank checking
    73. - End of blank checking
    74. - Start of blank checking
    75. - End of blank checking
    76. - Start of blank checking
    77. - End of blank checking
    78. - Start of blank checking
    79. - End of blank checking
    80. - Start of blank checking
    81. - End of blank checking
    82. - Start of blank checking
    83. - End of blank checking
    84. - Start of blank checking
    85. - End of blank checking
    86. - Start of blank checking
    87. - End of blank checking
    88. - Start of blank checking
    89. - End of blank checking
    90. - Start of blank checking
    91. - End of blank checking
    92. - Start of blank checking
    93. - End of blank checking
    94. - Start of blank checking
    95. - End of blank checking
    96. - Start of blank checking
    97. - End of blank checking
    98. - Start of blank checking
    99. - End of blank checking
    100. - Start of blank checking
    101. - End of blank checking
    102. - Start of blank checking
    103. - End of blank checking
    104. - Start of blank checking
    105. - End of blank checking
    106. - Start of blank checking
    107. - End of blank checking
    108. - Start of blank checking
    109. - End of blank checking
    110. - Start of blank checking
    111. - End of blank checking
    112. - Start of blank checking
    113. - End of blank checking
    114. - Start of blank checking
    115. - End of blank checking
    116. - Start of blank checking
    117. - End of blank checking
    118. - Start of blank checking
    119. - End of blank checking
    120. - Start of blank checking
    121. - End of blank checking
    122. - Start of blank checking
    123. - End of blank checking
    124. - Start of blank checking
    125. - End of blank checking
    126. - Start of blank checking
    127. - End of blank checking
    128. - Start of blank checking
    129. - End of blank checking
    130. - Start of blank checking
    131. - End of blank checking
    132. - Start of blank checking
    133. - End of blank checking
    134. - Start of blank checking
    135. - End of blank checking
    136. - Start of blank checking
    137. - End of blank checking
    138. - Start of blank checking
    139. - End of blank checking
    140. - Start of blank checking
    141. - End of blank checking
    142. - Start of blank checking
    143. - End of blank checking
    144. - Start of blank checking
    145. - End of blank checking
    146. - Start of blank checking
    147. - End of blank checking
    148. - Start of blank checking
    149. - End of blank checking
    150. - Start of blank checking
    151. - End of blank checking
    152. - Start of blank checking
    153. - End of blank checking
    154. - Start of blank checking
    155. - End of blank checking
    156. - Start of blank checking
    157. - End of blank checking
    158. - Start of blank checking
    159. - End of blank checking
    160. - Start of blank checking
    161. - End of blank checking
    162. - Start of blank checking
    163. - End of blank checking
    164. - Start of blank checking
    165. - End of blank checking
    166. - Start of blank checking
    167. - End of blank checking
    168. - Start of blank checking
    169. - End of blank checking
    170. - Start of blank checking
    171. - End of blank checking
    172. - Start of blank checking
    173. - End of blank checking
    174. - Start of blank checking
    175. - End of blank checking
    176. - Start of blank checking
    177. - End of blank checking
    178. - Start of blank checking
    179. - End of blank checking
    180. - Start of blank checking
    181. - End of blank checking
    182. - Start of blank checking
    183. - End of blank checking
    184. - Start of blank checking
    185. - End of blank checking
    186. - Start of blank checking
    187. - End of blank checking
    188. - Start of blank checking
    189. - End of blank checking
    190. - Start of blank checking
    191. - End of blank checking
    192. - Start of blank checking
    193. - End of blank checking
    194. - Start of blank checking
    195. - End of blank checking
    196. - Start of blank checking
    197. - End of blank checking
    198. - Start of blank checking
    199. - End of blank checking
    200. - Start of blank checking
    201. - End of blank checking
    202. - Start of blank checking
    203. - End of blank checking
    204. - Start of blank checking
    205. - End of blank checking
    206. - Start of blank checking
    207. - End of blank checking
    208. - Start of blank checking
    209. - End of blank checking
    210. - Start of blank checking
    211. - End of blank checking
    212. - Start of blank checking
    213. - End of blank checking
    214. - Start of blank checking
    215. - End of blank checking
    216. - Start of blank checking
    217. - End of blank checking
    218. - Start of blank checking
    219. - End of blank checking
    220. - Start of blank checking
    221. - End of blank checking
    222. - Start of blank checking
    223. - End of blank checking
    224. - Start of blank checking
    225. - End of blank checking
    226. - Start of blank checking
    227. - End of blank checking
    228. - Start of blank checking
    229. - End of blank checking
    230. - Start of blank checking
    231. - End of blank checking
    232. - Start of blank checking
    233. - End of blank checking
    234. - Start of blank checking
    235. - End of blank checking
    236. - Start of blank checking
    237. - End of blank checking
    238. - Start of blank checking
    239. - End of blank checking
    240. - Start of blank checking
    241. - End of blank checking
    242. - Start of blank checking
    243. - End of blank checking
    244. - Start of blank checking
    245. - End of blank checking
    246. - Start of blank checking
    247. - End of blank checking
    248. - Start of blank checking
    249. - End of blank checking
    250. - Start of blank checking
    251. - End of blank checking
    252. - Start of blank checking
    253. - End of blank checking
    254. - Start of blank checking
    255. - End of blank checking
    256. - Start of blank checking
    257. - End of blank checking
    258. - Start of blank checking
    259. - End of blank checking
    260. - Start of blank checking
    261. - End of blank checking
    262. - Start of blank checking
    263. - End of blank checking
    264. - Start of blank checking
    265. - End of blank checking
    266. - Start of blank checking
    267. - End of blank checking
    268. - Start of blank checking
    269. - End of blank checking
    270. - Start of blank checking
    271. - End of blank checking
    272. - Start of blank checking
    273. - End of blank checking
    274. - Start of blank checking
    275. - End of blank checking
    276. - Start of restoring
    277. - End of restoring
    278. - Target memory read successfully. (16777216 bytes, 1 range) - Completed after 12.299 sec
    279. Generating test data ...
    280. - 1 of 1 sectors selected, 1 range, 0xFC000000 - 0xFC0000FF
    281. - Test data generated successfully. (256 bytes, 1 range) - Completed after 0.023 sec
    282. Checking if selected data fits into selected flash sectors.
    283. Programming and verifying target (256 bytes, 1 range) ...
    284. - Start of determining flash info (Bank 0 @ 0xFC000000)
    285. - End of determining flash info
    286. - Flash bank info:
    287. - 512 * 64 KB @ 0xFC000000
    288. - Start of preparing flash programming
    289. - End of preparing flash programming
    290. - Start of determining dirty areas in flash cache
    291. - End of determining dirty areas
    292. - CPU speed could not be measured.
    293. - Start of erasing sectors
    294. - Start of blank checking
    295. - End of blank checking
    296. - Erasing range 0xFC000000 - 0xFC00FFFF (001 Sector, 64 KB)
    297. - End of erasing sectors
    298. - Start of flash programming
    299. - Programming range 0xFC000000 - 0xFC00FFFF (001 Sector, 64 KB)
    300. - End of flash programming
    301. - Flash programming performed for 1 range (65536 bytes)
    302. - 0xFC000000 - 0xFC00FFFF (001 Sector, 64 KB)
    303. - Start of verifying flash
    304. - End of verifying flash
    305. - Start of restoring
    306. - End of restoring
    307. - Target programmed and verified successfully (CRC = 0x1F5BA2F2) - Completed after 2.085 sec
    Since it works from Mentor Sourcery Codebench with J-Link for you, I am currently a little bit out of ideas....
    Do you have any further thoughts on this?
  • Hi Nicklas,
    Could you share the .jflash file you used so I can compare?
    I'll ask a colleague to give it a try on another ZC702 board.
    When running under Sourcery Codebench I've not programmed the flash just debugged my application.
  • Just realised you've said "Zedboard" in your last reply.
    This is a different board from the ZC702 evaluation board.
    Any ideas whether it should work or what changes are required?
    "Zynq 7020" is the device type we've been instructed by Mentor to use under Sourcery Codebench so I'd assumed it would be the same under JFlash/JLink commander.
    please find attached the J-Flash project I used.
    Its a auto-generated project, I just added the JTAG configuration via the "detect" option in the "Target Interface" tab of the project settings.
    • Zynq7020.jflash
      (1.78 kB, downloaded 662 times, last: )
  • Hi Niklas,
    I tried with the JFlash project you provided and I was still unable to program the flash - I've attached the zipped JLink.log for this attempt.
    I also tried auto-generating a new project with address size as 8KB and the resulting project file was identical to yours apart from the ID for Device0 in the JTAG section as follows:-
    mine Device0_ID = 0x23727093
    yours Device0_ID = 0x03727093
    But I think this Device is for the Programmable Logic, i.e. FPGA, within the Zynq so should not matter.
    As I mentioned in an earlier post the Zedboard you'd tested with is a different board from the ZC702 eval board although they both share the same Zynq processor.
    Perhaps I need to make some modifications.
    Thanks.
    • JLink.zip
      (25.57 kB, downloaded 518 times, last: )
    Looking forward to hearing of your results!
    Are you refering to this board?
    xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html
    Unfortunately we do not have this board in our collection of reference boards.
    I would suggest the following two tests using J-Link Commander (JLink.exe):
    1. Connect to target by executing >connect<
    2. Test if download to RAM works using the >testwspeed<
    testwspeed 0
    3. Test if executing code from RAM works
    This can be done by any routine, a most basic one would be:
    1. 0x0000: 0xE2800001; // Loop: ADD R0, R0, #1
    2. 0x0004: 0xEAFFFFFD; // B(-2) --> Loop
    Memory can be writen using the >w4 <Addr>, <Data>< command.
    The commands >g<, >h<, >s< can be used for go, halt and step (or e.g the "TestHaltGo" command) in order to test if halt/go works and if the counter in R0 is incremented as expected.
  • Hi Niklas,
    I was able to confirm that downloading to RAM and also executing from RAM both work for the target system.
    Output from JLink is pasted below.
    I understand the Zedboard has a different sized QSPI flash - could that be the reason?
    Also tried adding JFlash initialisation steps equivalent to the initialisation performed by the debugger under Source Codebench but still no luck.
    SEGGER J-Link Commander V6.18 (Compiled Aug 3 2017 16:19:59)
    DLL version V6.18, compiled Aug 3 2017 16:19:24
    Firmware: J-Link V10 compiled Jul 28 2017 08:59:01
    Hardware version: V10.10
    S/N: 600104810
    VTref = 3.348V
    J-Link>connect
    Please specify device / core. <Default>: ZYNQ 7020
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    TIF>
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>
    Device "ZYNQ 7020" selected.
    Connecting to target via JTAG
    TotalIRLen = 10, IRPrint = 0x0051
    JTAG chain detection found 2 devices:
    #0 Id: 0x23727093, IRLen: 06, Unknown device
    #1 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
    ARM AP[0]: 0x44770001, AHB-AP
    ARM AP[1]: 0x24770002, APB-AP
    ROMTbl[0][0]: CompAddr: 80001000 CID: B105900D, PID:04-003BB907 ETB
    ROMTbl[0][1]: CompAddr: 80002000 CID: B105900D, PID:04-002BB906 ECT / CTI
    ROMTbl[0][2]: CompAddr: 80003000 CID: B105900D, PID:04-004BB912 TPIU
    ROMTbl[0][3]: CompAddr: 80004000 CID: B105900D, PID:04-001BB908 CSTF
    ROMTbl[0][4]: CompAddr: 80005000 CID: B105900D, PID:04-002BB913 ITM
    ROMTbl[0][5]: CompAddr: 80009000 CID: B105900D, PID:04-002BB906 ECT / CTI
    ROMTbl[0][6]: CompAddr: 8000A000 CID: B105900D, PID:04-002BB906 ECT / CTI
    ROMTbl[0][7]: CompAddr: 8000B000 CID: B105900D, PID:00-000C9001
    ROMTbl[0][8]: CompAddr: 8000C000 CID: B105900D, PID:03-072893B2
    ROMTbl[0][9]: CompAddr: 80080000 CID: B105100D, PID:04-000BB4A9 ROM Table
    ROMTbl[1][0]: CompAddr: 80090000 CID: B105900D, PID:04-000BBC09 Cortex-A9
    Found Cortex-A9 r3p0
    6 code breakpoints, 4 data breakpoints
    Debug architecture ARMv7.0
    Data endian: little
    Main ID register: 0x413FC090
    I-Cache L1: 32 KB, 256 Sets, 32 Bytes/Line, 4-Way
    D-Cache L1: 32 KB, 256 Sets, 32 Bytes/Line, 4-Way
    System control register:
    Instruction endian: little
    Level-1 instruction cache disabled
    Level-1 data cache disabled
    MMU disabled
    Branch prediction disabled
    Cortex-A9 identified.
    J-Link>r
    Reset delay: 0 ms
    Reset type NORMAL: Toggle reset pin and halt CPU core.
    J-Link>h
    PC: (R15) = 00000000, CPSR = 900001DF (System mode, ARM FIQ dis. IRQ dis.)
    Current:
    R0 =F8007028, R1 =FFFFFFFF, R2 =4C00E07F, R3 =F8007000
    R4 =FFFFFF00, R5 =FFFFFF04, R6 =00000018, R7 =F8000004
    R8 =00000008, R9 =00000008, R10=0000767B, R11=E3E0F0D3, R12=F8000244
    R13=EA000049, R14=00000000
    USR: R8 =0000767B, R9 =E3E0F0D3, R10=F8000244, R11=EA000049, R12=00000000
    R13=E5801000, R14=00000000
    FIQ: R8 =00000000, R9 =00000000, R10=00000000, R11=00000000, R12=00000000
    R13=00000000, R14=00000000, SPSR=600F0051
    IRQ: R13=00000000, R14=00000000, SPSR=600F0052
    SVC: R13=00000000, R14=00000048, SPSR=600F0053
    ABT: R13=00000000, R14=00000000, SPSR=600F0057
    UND: R13=00000000, R14=00000000, SPSR=600F005B
    J-Link>wreg R0,0
    R0 = 0x00000000
    J-Link>SetPC 0
    J-Link>w4 0,e2800001
    Writing E2800001 -> 00000000
    J-Link>w4 4,eafffffd
    Writing EAFFFFFD -> 00000004
    J-Link>regs
    Current:
    R0 =00000000, R1 =FFFFFFFF, R2 =4C00E07F, R3 =F8007000
    J-Link>s
    00000000: 01 00 80 E2 ADD R0, R0, #0x01
    J-Link>s
    00000004: FD FF FF EA B #-0x0C ; 0x00000000
    J-Link>s
    J-Link>s
    J-Link>s
    J-Link>regs
    PC: (R15) = 00000004, CPSR = 900001DF (System mode, ARM FIQ dis. IRQ dis.)
    Current:
    R0 =00000003, R1 =FFFFFFFF, R2 =4C00E07F, R3 =F8007000
    R8 =0000000C, R9 =0000000C, R10=0000767B, R11=E3E0F0D3, R12=F8000244
    J-Link>testwspeed
    Speed test: Writing 8 * 128kb into memory @ address 0x00000000 ........
    128 kByte written in 458ms ! (286.0 KByte/sec)
    Could you provide us with the initialization steps executed by Codebench?
    I can then compare them with what we do internally for the Zedboard......
  • Hi Niklas,
    I've attached a JLink log from when I'm starting a debug session from Codebench.
    I've also attached the JFlash project in which I've added init steps.
    Thanks for your continued attention.
    Regards.
    • JLink_Log.zip
      (4.35 kB, downloaded 516 times, last: )
    • zc702.jflash
      (19.51 kB, downloaded 681 times, last: )
    The QSPI flash used on the eval board is a N25Q128A, which should work fine.
    Would it be possible for you to provide us access to the board via a J-Link remote Server (Tunnel mode) session?
    10-15 minutes of access time should be enough.
    an alternative to setting it up via the company network would be to connect J-Link to a a laptop which is not connected to the company network,
    but instead connected directly or via a mobile phone to a 3G or LTE Network.
    Unfortunately, a teamviewer session does not help, since I need to work with a debug version of our software, which I cannot run on your computer.
    thanks for providing access to the board.
    You can close the tunnel session.
    We do not get a valid ID (communication error) from the QSPI flash, although it works on the Zedboard which features the same MCU and connects the QSPI flash to the same pins.
    We assume that the board is unaltered and that Xilinx does not ship $900 boards w/o QA.
    Therefore, I assume it is more generic issue on our side which occurs on this board.
    I requested the eval board from our management. Unfortunately, this might take a while...
    In order to speed things up, would it be possible for you to provide us temporally with the evaluation board?
