[SOLVED] Cortex M0+ NoOS Port Read Active Interrupt ID
  • [SOLVED] Cortex M0+ NoOS Port Read Active Interrupt ID
    Hello
    Im trying to port SystemView to the Coretex M0+ uC.
    I could send Task Info and Print to the SystemView Terminal but i have Problems to monitor the Interrupts.
    According to:
    infocenter.arm.com/help/index.…oc.dui0662b/CIHFDJCA.html
    4.3.3 Interrupt Control and State Register
    The VECTACTIVE Part of the ICSR Register is marked as Reserved.
    1. SEGGER_SYSVIEW_GET_INTERRUPT_ID() ((*(U32 *)(0xE000ED04)) & 0x3F)
    Makro Returns 0 i think.
    If i try to use the SystemView Interupt Functions:
    1. SEGGER_SYSVIEW_RecordEnterISR();
    2. SEGGER_SYSVIEW_RecordExitISR();
    I got al lot of ISR Enter and ISR Exit Events in the Segger Systemview PC Tool (see the Attachment).
    Do you have any suggestions how i could fix this?
    You are right, Cortex-M0+ devices do not have the ICSR[VECTACTIVE] bits implemented.
    Instead you can read the active vector from the IPSR, best implemented in a user-provided function SEGGER_SYSVIEW_X_GetInterruptId():
    2. *
    3. * SEGGER_SYSVIEW_X_GetInterruptId()
    4. *
    5. * Function description
    6. * Return the currently active interrupt Id,
    7. * which ist the active vector taken from IPSR[5:0].
    8. *
    9. * Return value
    10. * The current currently active interrupt Id.
    11. *
    12. * Additional information
    13. * This function is not used by default, as the active vector can be
    14. * read from ICSR instead on Cortex-M0.
    15. * For Cortex-M0+ devices, change SEGGER_SYSVIEW_GET_INTERRUPT_ID
    16. * in SEGGER_SYSVIEW_Conf.h to call this function instead.
    17. */
    18. U32 SEGGER_SYSVIEW_X_GetInterruptId(void) {
    19. U32 Id;
    20. __asm volatile ("mrs %0, ipsr"
    21. : "=r" (Id)
    22. );
    23. Id &= 0x3F;
    24. return Id;
    25. }
    Johannes
    I get the same problem, I am using STM32F091RC nucleo board, and as interrupt ID is not detected so interrupt handler is recognized as an idle state.
    I tried the __asm volatile ("mrs %0, ipsr" : "=r" (Id) );
    solution mentioned above, but get a compilation error: missing ")" character. I am using Keil5 with default compilation settings.
    Could you please tell me how you solved this problem?
    Thanks!
    Thanks, it works! But it still has a problem: it cannot get how many ticks the interrupt runs, which means even if I ran the interrupt for several seconds, it shows only one cycle. I cannot find SEGGER_SYSVIEW_X_GetTimestamp() function called in SEGGER_SYSVIEW_RecordEnterISR(); and SEGGER_SYSVIEW_RecordExitISR();. Do I need to manually do something in the interrupt?
    Thanks for help!
    SEGGER_SYSVIEW_X_GetTimestamp() will be called in the recording function called by SEGGER_SYSVIEW_Record*().
    You do not have to modify them.
    If the recording shows only one cycle, make sure that the implementation of SEGGER_SYSVIEW_X_GetTimestamp() does work.
    Refer to the sample configurations given for the various supported systems.
    Johannes
