[SOLVED] Problems with updating J-Link Firmware V6.16j
  • [SOLVED] Problems with updating J-Link Firmware V6.16j
    today I installed the J-Link Software V6.16j and tried to update the firmware of the J-Link.
    But something does not work correctly.
    I attached a screenshot of the Log-window.
    I have to dis-/reconnect the J-Link after updating to detect it in again.
    The firmware info then still shows the old version number.
    Anyone else experiences this problem?
    Martin
  • Hi Martin,
    there is no Firmware version number.
    What is the firmware string?
    It looks like this:
    Firmware: J-Link Pro V4 compiled Jul 24 2017 17:06:05
  • Hi Martin,
    Could you post a screenshot showing what you are referring to with "version number"?
    please don't get this wrong - I just wanted to be sure that we are talking about the same thing.
    I had many inquiries where J-Link software version number and firmware string have been confused.
    What happens if you open J-Link commander(jlink.exe) and accept the firmware update?
    Does it fail every time?
  • Hi Niklas,
    no problem, speaking about the same things is important.
    The Log Window (which is shown during the update process) shows exactly the same as in my screenshot, when using the J-Link Commander.
    The J-Link commander window shows this:
    1. SEGGER J-Link Commander V6.16j (Compiled Jul 24 2017 18:42:58)
    2. DLL version V6.16j, compiled Jul 24 2017 18:42:23
    3. Connecting to J-Link via USB...Updating firmware: J-Link Pro V4 compiled Jul 24 2017 17:06:05
    4. Replacing firmware: J-Link Pro V4 compiled Jul 10 2017 15:44:26
    5. Waiting for new firmware to boot
    6. FAILED: Communication timed out: Requested 4 bytes, received 0 bytes !
    7. Could not read J-Link capabilities.
    8. J-Link>
    Martin
  • Hi Martin,
    could you please give it a try using another PC (Windows/Linux/macOS is OK) and another USB-Cabel while having the J-Link connected directly to the machine, with no HUB etc in between?
  • Hi Niklas,
    I found the issue.
    The J-LInk was connected via a "J-Link USB Isolator".
    After removing the isolator the update went fine.
    It seems, that the J-Link update process does not like the isolator.
    Is this a known limitation, that the isolator may not be connected during a firmware update?
    Martin
  • Hi Martin,
    Yes, this is a know limitation.
    I am sorry that I did not think of the possibility that you are using a J-Link USB Isolator.
