TouchScreen orientation and GUI_MEMDEV_RotateHQT
  • TouchScreen orientation and GUI_MEMDEV_RotateHQT
    Hello!
    I'm new here, thank you so much for developing such an amazing product.
    I have few questions:
    I'm on stm32f429i discorvery, everything is working fine, but when I try to rotate the screen using driver "#define DISPLAY_DRIVER_0 GUIDRV_LIN_OSX_32", the touch detection is messed up (rotated). I have tried to use following in my main:
    /* Init the STemWin GUI Library */
    U32 TouchOrientation;
    TouchOrientation = (GUI_MIRROR_X * LCD_GetMirrorX()) |
    (GUI_MIRROR_Y * LCD_GetMirrorY()) |
    (GUI_SWAP_XY * LCD_GetSwapXY()) ;
    GUI_TOUCH_SetOrientation(TouchOrientation);
    GUI_Init();
    GUI_Initialized = 1;
    /* Activate the use of memory device feature */
    WM_SetCreateFlags(WM_CF_MEMDEV);
    but that doesn't seem to do the trick.
    Second thing is, I export the transparent bitmaps in .c format using bitmapconverter. I load them and rotate in such a way:
    GUI_MEMDEV_Select(src2);
    GUI_Clear();
    GUI_SetBkColor(GUI_TRANSPARENT);
    GUI_DrawBitmap(&bmblat1_pod,0,0);
    GUI_MEMDEV_RotateHQ(src2,hDst ,17,115,-90*1000,1*1000);
    That produces good result. But I have read the documentation and there is such a function "GUI_MEMDEV_RotateHQT" optimised for bitmaps with transparent pixels (seems like a great deal for me), but once I change the function to "GUI_MEMDEV_RotateHQT" the program goes into infinite loop handler. Here is my GUIconf:
    #define GUI_NUMBYTES ((1024) * 1500)
    #define GUI_BUFFER_IN_EXT_RAM 1
    #define GUI_BUFFER_ADDRESS 0xD0900000
    #define OS_SUPPORT 1
    Could you please give me some advice on this? Also can I draw .dta files containing transparent pixels instead of .c bitmaps? Will it be faster (the file size seem to be smaller)? Thank you again for delivering such a great product.
    Unfortunately, GUI_TOUCH_SetOrientation() works only with analog touch input where raw A/D converter values are getting passed to emWin.
    In your case you have to re-calculate the pixel coordinates on your own.
    I checked the function GUI_MEMDEV_RotateHQT(), it is working as expected.
    What is the size of the memory devices you are using?
    Keep in mind that a memory device requires some amount of memory and it can be possible that you exceed the limits quite fast. But I think this not the reason in this case. Even two memory devices with a size of 320 x 240 pixel would require 600KB which should fit easily into the GUI memory.
    Please try the code below (change 'aBitmap' into the bitmap you want to draw):
    1. void MainTask(void) {
    2. GUI_MEMDEV_Handle hMemSrc;
    3. GUI_MEMDEV_Handle hMemDst;
    4. GUI_Init();
    5. hMemSrc = GUI_MEMDEV_Create(0, 0, aBitmap.XSize, aBitmap.YSize);
    6. hMemDst = GUI_MEMDEV_Create(0, 0, aBitmap.XSize, aBitmap.YSize);
    7. GUI_MEMDEV_Select(hMemSrc);
    8. GUI_SetBkColor(GUI_TRANSPARENT);
    9. GUI_Clear();
    10. GUI_DrawBitmap(&aBitmap, 0, 0);
    11. GUI_MEMDEV_Select(0);
    12. GUI_MEMDEV_RotateHQT(hMemSrc, hMemDst , 0, 0, 90 * 1000, 1 * 1000);
    13. GUI_MEMDEV_WriteAt(hMemDst, 10, 10);
    14. while(1) {
    15. GUI_Delay(500);
    16. }
    17. }
    dta-files are the same as c bitmap file. But instead of c code they are stored in a binary form. Their intention is to be placed on external memory (like an SD card). The drawing process itself is as fast as c-bitmaps but the they need get loaded from the memory first which will make the whole process slower.
    You should stick to c-files if want a fast output.
    Choose the format you are saving the bitmap in according to your LCDConf.c.
    Depending on the color conversion (GUICC_xxx) you should save the bitmap in the proper format:
    GUICC_M8888I - 'True color with alpha, alpha inverted, red and blue swapped'
    GUICC_M565 - 'High color (565), red and blue swapped'
    The same is true for dta-files, if you have an external memory to read from.
  • Thank you very much for the info Sven!
    I have one more question, is this the kind of performance that I should get or am I doing something wrong? (the clock is set to 180mhz - if I slightly overclock it goes little bit more smooth)
    youtu.be/HXnnclIkvdc
    Or have I something about DMA2D configured not right what do you think?
    I also plan to change the screen to 7" with an SSD1963 controller, can you tell me if I won't have problems with transparency (using GUIDRV_FlexColor and 18bit interface)?
    Thanks again, this forum is very helpful :)
    Unfortunately, you have to use the default orientation to get the full advantage of the DMA2D.
    Only the copy buffer functionality is working in a rotated orientation. This is due to hardware limitation.
