Installation of Ozone on new computer crashes when attempting to view FreeRTOS threads
  • Installation of Ozone on new computer crashes when attempting to view FreeRTOS threads
    I've recently moved to a new computer and installed Ozone 2.42. When trying to view tasks with a project using freeRTOS (View->FreeRTOS->Tasks) Ozone crashes. It only crashes if the task view is enabled.
    I'm on a fresh Windows 7 installation, running Ozone through a j-trace and j-trace pro on an STM32F7. I've tried uninstalling and re-installing with no luck, as well as installing an older version of Ozone, but the crash persists when trying to view freeRTOS tasks.
    Any suggestions?
    The error follows:
    "Problem signature:
    Problem Event Name: APPCRASH
    Application Name: Ozone.exe
    Application Version: 2.4.2.0
    Application Timestamp: 594bb22e
    Fault Module Name: ntdll.dll
    Fault Module Version: 6.1.7601.23807
    Fault Module Timestamp: 5915fdce
    Exception Code: c0000005
    Exception Offset: 000000000004f23c
    OS Version: 6.1.7601.2.1.0.256.48
    Locale ID: 1033
    Additional Information 1: d54b
    Additional Information 2: d54b2e50f8000514d2345d55eaebc4ac
    Additional Information 3: bbcf
    Additional Information 4: bbcfb80054e569d43ef7909c45db91f0
    Also, here's some information from Microsoft's "Application Verifier"
    XML Source Code
    1. <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    2. <avrf:logfile xmlns:avrf="Application Verifier">
    3. <avrf:logSession TimeStarted="2017-07-07 : 11:32:25" PID="9856" Version="2">
    4. <avrf:logEntry Time="2017-07-07 : 11:35:42" LayerName="Heaps" StopCode="0x13" Severity="Error">
    5. <avrf:message>First chance access violation for current stack trace.</avrf:message>
    6. <avrf:parameter1>69b1d7000 - Invalid address causing the exception.</avrf:parameter1>
    7. <avrf:parameter2>7900c032 - Code address executing the invalid access.</avrf:parameter2>
    8. <avrf:parameter3>1b9e30 - Exception record.</avrf:parameter3>
    9. <avrf:parameter4>1b9940 - Context record.</avrf:parameter4>
    10. <avrf:stackTrace>
    11. <avrf:trace>vrfcore!VerifierDisableVerifier+934 ( @ 0)</avrf:trace>
    12. <avrf:trace>ntdll!RtlApplicationVerifierStop+d3 ( @ 0)</avrf:trace>
    13. <avrf:trace>vfbasics!+7fed69d6377 ( @ 0)</avrf:trace>
    14. <avrf:trace>vfbasics!+7fed69d7c9b ( @ 0)</avrf:trace>
    15. <avrf:trace>vfbasics!+7fed69d7392 ( @ 0)</avrf:trace>
    16. <avrf:trace>ntdll!vsprintf_s+12b ( @ 0)</avrf:trace>
    17. <avrf:trace>ntdll!RtlUnwindEx+852 ( @ 0)</avrf:trace>
    18. <avrf:trace>ntdll!KiUserExceptionDispatcher+2e ( @ 0)</avrf:trace>
    19. <avrf:trace>MSVCR100!memmove+d2 ( @ 0)</avrf:trace>
    20. <avrf:trace>Ozone!+13f5f2800 ( @ 0)</avrf:trace>
    21. <avrf:trace>Ozone!+13f5f2912 ( @ 0)</avrf:trace>
    22. <avrf:trace>Ozone!+13f43646a ( @ 0)</avrf:trace>
    23. <avrf:trace>Ozone!+13f437549 ( @ 0)</avrf:trace>
    24. <avrf:trace>Ozone!+13f5a2198 ( @ 0)</avrf:trace>
    25. <avrf:trace>FreeRTOSPlugin!+7fee4c01b56 ( @ 0)</avrf:trace>
    26. <avrf:trace>FreeRTOSPlugin!+7fee4c01db8 ( @ 0)</avrf:trace>
    27. <avrf:trace>FreeRTOSPlugin!+7fee4c0200f ( @ 0)</avrf:trace>
    28. <avrf:trace>FreeRTOSPlugin!+7fee4c02968 ( @ 0)</avrf:trace>
    29. <avrf:trace>FreeRTOSPlugin!+7fee4c02c2d ( @ 0)</avrf:trace>
    30. <avrf:trace>Ozone!+13f5da430 ( @ 0)</avrf:trace>
    31. <avrf:trace>Ozone!+13f523204 ( @ 0)</avrf:trace>
    32. <avrf:trace>Ozone!+13f6038cb ( @ 0)</avrf:trace>
    33. <avrf:trace>QtCore4!QMetaObject::activate+53c ( @ 0)</avrf:trace>
    34. <avrf:trace>Ozone!+13f602e6e ( @ 0)</avrf:trace>
    35. <avrf:trace>QtCore4!QMetaObject::activate+53c ( @ 0)</avrf:trace>
    36. <avrf:trace>QtGui4!QDockWidget::visibilityChanged+33 ( @ 0)</avrf:trace>
    37. <avrf:trace>QtGui4!QDockWidget::event+a4 ( @ 0)</avrf:trace>
    38. <avrf:trace>QtGui4!QApplicationPrivate::notify_helper+f6 ( @ 0)</avrf:trace>
    39. <avrf:trace>QtGui4!QApplication::notify+1818 ( @ 0)</avrf:trace>
    40. <avrf:trace>QtCore4!QCoreApplication::notifyInternal+72 ( @ 0)</avrf:trace>
    41. <avrf:trace>QtGui4!QWidgetPrivate::show_helper+208 ( @ 0)</avrf:trace>
    42. <avrf:trace>QtGui4!QWidget::setVisible+30c ( @ 0)</avrf:trace>
    43. <avrf:trace>Ozone!+13f500718 ( @ 0)</avrf:trace>
    44. <avrf:trace>Ozone!+13f5fb6a6 ( @ 0)</avrf:trace>
    45. <avrf:trace>QtCore4!QMetaObject::activate+53c ( @ 0)</avrf:trace>
    46. <avrf:trace>QtGui4!QAction::activate+e0 ( @ 0)</avrf:trace>
    47. <avrf:trace>Ozone!+13f5b0346 ( @ 0)</avrf:trace>
    48. <avrf:trace>Ozone!+13f5b0565 ( @ 0)</avrf:trace>
    49. <avrf:trace>Ozone!+13f5005bc ( @ 0)</avrf:trace>
    50. <avrf:trace>Ozone!+13f5fb6b3 ( @ 0)</avrf:trace>
    51. <avrf:trace>QtCore4!QMetaObject::activate+53c ( @ 0)</avrf:trace>
    52. <avrf:trace>QtGui4!QAction::activate+e0 ( @ 0)</avrf:trace>
    53. <avrf:trace>QtGui4!QMenu::findIdForAction+328 ( @ 0)</avrf:trace>
    54. <avrf:trace>QtGui4!QMenu::internalDelayedPopup+8c2 ( @ 0)</avrf:trace>
    55. <avrf:trace>QtGui4!QWidget::event+d5 ( @ 0)</avrf:trace>
    56. <avrf:trace>QtGui4!QMenu::event+2a3 ( @ 0)</avrf:trace>
    57. <avrf:trace>QtGui4!QApplicationPrivate::notify_helper+f6 ( @ 0)</avrf:trace>
    58. <avrf:trace>QtGui4!QApplication::notify+720 ( @ 0)</avrf:trace>
    59. <avrf:trace>QtCore4!QCoreApplication::notifyInternal+72 ( @ 0)</avrf:trace>
    60. <avrf:trace>QtGui4!QApplicationPrivate::sendMouseEvent+1de ( @ 0)</avrf:trace>
    61. <avrf:trace>QtGui4!QApplication::winFocus+9db ( @ 0)</avrf:trace>
    62. <avrf:trace>QtGui4!QApplication::restoreOverrideCursor+93d ( @ 0)</avrf:trace>
    63. <avrf:trace>USER32!TranslateMessageEx+29d ( @ 0)</avrf:trace>
    64. <avrf:trace>USER32!TranslateMessage+1e2 ( @ 0)</avrf:trace>
    65. <avrf:trace>QtCore4!QEventDispatcherWin32::processEvents+3ba ( @ 0)</avrf:trace>
    66. <avrf:trace>QtGui4!QApplicationPrivate::translateTouchEvent+885 ( @ 0)</avrf:trace>
    67. <avrf:trace>QtCore4!QEventLoop::exec+231 ( @ 0)</avrf:trace>
    68. <avrf:trace>QtCore4!QCoreApplication::exec+e0 ( @ 0)</avrf:trace>
    69. <avrf:trace>Ozone!+13f5f5169 ( @ 0)</avrf:trace>
    70. <avrf:trace>Ozone!+13f6258ce ( @ 0)</avrf:trace>
    71. <avrf:trace>kernel32!BaseThreadInitThunk+d ( @ 0)</avrf:trace>
    72. <avrf:trace>ntdll!RtlUserThreadStart+21 ( @ 0)</avrf:trace>
    73. </avrf:stackTrace>
    74. </avrf:logEntry>
    75. </avrf:logSession>
    76. </avrf:logfile>
    The FreeRTOS plugin in general works, so we would need more information to analyze the problem.
    Are you using the 64-bit or 32-bit version?
    Which version of FreeRTOS do you use?
    Would it be possible to provide your application elf file?
    Do you use a standard eval board or custom hardware?
    Could you provide a Ozone log file of a crashed session? (start Ozone with --logfile=<PathToLogfile>)
    Johannes
  • Yes, the FreeRTOS plugin has been working well for us across multiple machines, hardware platforms and firmware projects for months. I'm not sure what happened. We even have a laptop that sat untouched for a month which no longer works with the same two jtrace programmers we've been using.
    Also of note: I noticed on one machine Ozone uses all available RAM (~14GB) when opening a project file, which I don't remember being normal behavior. . .
    The answers to your previous questions:
    - We're using Windows 7 64 bit
    - FreeRTOS 9.0.0
    - I'll PM a hex file (and the project file)
    - custom hardware (3 different boards and two different MCU's, none of which don't work now)
    - log is attached (logging had to be started in the project file rather than from the command line)
    thanks,
    Brian
    • ozoneLog.txt
      (27.26 kB, downloaded 533 times, last: )
