[SOLVED] Why doesn't flashing OpenSDA firmware work on OSX?
  • [SOLVED] Why doesn't flashing OpenSDA firmware work on OSX?
    I have a brand new FRDM-KL25Z board. It ships with an OpenSDA firmware which is compatible with a P&E debugger. I tried to replace the firmware with one from SEGGER using my Macbook Pro running OS X 10.12.5.
    Here's the steps I went through:
    - Hold down the reset button on the FRDM board and connect to OSX via USB
    - Board appears as "BOOTLOADER" drive
    - Copy the 12_OpenSDA_FRDM-KL25Z.bin onto the root of this drive
    - Unplug the FRDM board and plug it back in
    What happened:
    - Nothing - the board has the original P&E firmware on it.
    When I try the exact same steps on a Windows10 machine the firmware is updated successfully and I can connect via J-Link.
    Why doesn't firmware flashing work on OSX?
    This is a limitation of the OpenSDA bootloader, which can not be lifted by SEGGER.
    Please note that it is explicitly mentioned on the website that OpenSDA firmware flashing is not supported on macOS.
    segger.com/products/debug-prob…r-j-links/opensda-sda-v2/
