[ABANDONED] J link gdb server problem
  • [ABANDONED] J link gdb server problem
    Hello guys,
    I try to load my program on my ECU using j link but it says that :
    WARNING: CPU could not be halted
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    Shutting down...
    Please check power, connection and settings.
    but i used the same configuration with a discovery and it works (I've upgraded the st link on the discovery to a j link).
    and thank you for your time
    could you please give J-Link Commander a try?
    J-Link commander is part of the J-Link software package, which is available free of charge here .
    • Start J-Link Commander (jlink.exe)
    • Type "connect" in order to start a debug session
    • Type in the target device name if asked (Or type "?" for a target selection Dialog)
    • Choose the correct target interface (JTAG/SWD/etc..)
    • Use a valid speed (Default: 4000kHz, try 100-500 if default does not work)
    • [JTAG only]JTAG conf can be default(most of the times)
    • You should now be successfully connected.
    If anything fails, could you please post a screenshot of the complete session?
    What target device do you use?
    Version V5.10u is quite old.
    Could you please give the current version of the J-Link software & documentation pack a try?
    Please provide us with a screenshot of the session if the issue persists.
    as mentioned before, could you please give the most recent J-Link software & documentation pack a try and provide us with a screenshot of J-Link Commander and log files if anything fails?
    Log output can be enabled like as follows:
    • Open a connection to J-Link, e.g start J-Link Commander
    • In J-Link Control Panel: (Click the J-Link symbol located in the notification / tray area in order to open J-Link Control panel)
    • Open the tab "Settings"
    • Next to the field "Log file" check "Override" and click "..." in order to choose a log file path.
    This is also described in UM8001 Chapter 5 "Working with J-Link and J-Trace", Section 5.7 "J-Link control panel" .
    This will enable the logfile permantly, also for feature sessions, regardless which programm uses the J-link DLL.
