V250 no longer works
  • V250 no longer works
    I have been using V242 under Linux (Centos 7). I just tried running V250 and it fails to run.
    Could not open J-Link shared library. Exiting now.
    Did the current version add a check for the J-Link library? I am running oneshot capture to memory with manual download on ARM7.
    Is this an oversight or deliberate? I don't have or need the J-Link library for my target.
    The post was edited 1 time, last by krbvroc1 ().
    Thank you for the report.
    You are right, SystemView V2.50 currently needs the J-Link library to check for SystemView PRO licenses on connected J-Links.
    Since it should not be required to have the J-Link software installed, we will add a check for library presence before the license check.
    So with the upcoming version you should be able to use SystemView again without the J-Link Software.
    Johannes
