[SOLVED] RTOS plugin initialization failed.
  • [SOLVED] RTOS plugin initialization failed.
    I am trying to use the FreeRTOS plugin with the GDBServerCL.
    I can only see one thread in Eclipse, and there is the following line in the GDBServer log: RTOS plugin initialization failed.
    My setup:
    IDE - Eclipse Neon.3 v4.6.3 running on Windows 8.1 64 bit.
    Debugger - arm-none-eabi-gdb running on Windows 8.1 64 bit.
    GDBServer - GDBServerCL v6.16b running on Windows 7 Ultimate SP1 32 bit.
    FreeRTOS v9.0.0
    Target CPU - ARM Cortex-R5
    GDBServer log file is attached.
    Any help is highly appreciated.
    Thanks!
    the FreeRTOS plugin is currently not tested with the Cortex-R CPU and therefore refuses to work with other cores than Cortex-M.
    What device and IDE are you using?
    Arne
  • Hello Arne,
    Thank you for your fast reply!
    The IDE I am using is Eclipse Neon.3 v4.6.3 running on Windows 8.1 64 bit.
    The device is a custom SOC with an ARM Cortex-R5 CPU.
    Is there any workaround for this issue?
    Thanks!
    you can write the plugin by yourself, we offer a SDK for that purpose.
    J-Link GDB Server RTOS plug-in SDK
    I had a quick look at the port for Cortex-R. As it uses a different method to save the task context, the plugin for Cortex-M will not work.
    Arne
