[SOLVED] NXP iMX7 Solo
  • [SOLVED] NXP iMX7 Solo
    Hi, I see at the wiki that NXP iMX7 solo is supported, but I don't find the device in the listings and I don't find any script-files on wiki.
    How do I use J-link commander with the solo series? I have had no success halting the processor with the dual core device scripts.
    Any help will be very appreciated.
    thanks for your inquiry.
    The NXP iMX7S series devices (MCIMX7S3, MCIMX7S5) do neither have internal flash nor are they multi-core devices.
    Therefore no device-specific handling or J-Link script file is necessary.
    Debugging should just work when specifying Cortex-A7 as the device/core name.
    However, we will add MCIMX7S3 and MCIMX7S5 to the supported device list in a future version of the J-Link software & documentation pack in order to avoid further confusion.
  • Ok, thanks. So do you have any idea why I cannot halt the processor? I do see "Found Cortex-A7 r0p5" message when I connect, and therefore I assume the JTAG interface is functional. But all other commands fail by "CPU is not halted !"
    I have measured that all voltages and clocks are within specifications. What can halt the processor then, and how to avoid it?
    do I understand you correctly that the issue occurs if you do *not* use the dual core device scripts?
