Ozone on Linux does not start
  • Ozone on Linux does not start
    Hi All,
    after upgrading Ozone from 2.32 to 2.40 ist does not start anymore (Linux Mint 18.1 64bit).
    The console shows the following error:
    Cannot mix incompatible Qt library (version 0x40807) with this library (version 0x40806)
    Ozone V2.32 worked on this system.
    Is there something I can do about this?
    Downgrading doesn't work, because I don't know how to remove the V2.40 before installing V2.32 again.
    Any help is appreciated.
    Thanks in advance, Martin
  • Hi Martin,
    could you please provide us with the output of ldd Ozone and the J-Link library
    (e.g. ldd -v /org/SEGGER/$PATH/libjlinkarm.so)
    Could you also check the version of each qt lib listed?
    Sounds to me as if only some libs were updated to 4.8.7 and some are still 4.8.6
  • Hi Niklas,
    thanks for the quick response.
    Here is the output of ldd -v /opt/Segger/ozone/2..40.2/ozone:
    See attachement Ozone-log.txt
    Here is the output of ldd -v /opt/Segger/Jlink/libjlinkarm.so:
    See attachement JLink-log.txt
    ldconfig -v | grep libQtGui.so.4
    returns the following:
    libQtGui.so.4 -> libQtGui.so.4.8.7
    ldconfig -v | grep libQtCore.so.4
    libQtCore.so.4 -> libQtCore.so.4.8.7
    Let me know, if you need more information.
    Martin
    • Ozone-log.txt
      (12.17 kB, downloaded 171 times, last: )
    • JLink-log.txt
      (3.36 kB, downloaded 203 times, last: )
  • Hi Martin,
    Could you please open a ticket by writing a mail to the address I will send you via PM?
    Please include
    - a short summary of the issue
    - a link to his thread
    - the S/N of your J-Link Pro
    This will make sure that your are added to the queue of pending Ozone issues.
  • Hi Martin,
    they found the issue, it will be fixed in version 2.40d of Ozone.
    As an alternative, it should work with version 2.40c after you deleted the following symlinks:
    - Ozone/Lib/libQtGui.so.4
    - Ozone/Lib/libQtCore.so.4
  • Hi Martin,
    thanks for the update!
  • Hi Niklas,
    Unfortunately, I cannot confirm this:
    Today I updated Ozone to version 2.40.4 by first uninstalling version 2.40.3 and then installing 2.40.4.
    I got the same library error again.
    I still had to manually delete the symlinks to get Ozone starting.
    Martn
  • for some (strange!) reasons, the ozone deb packages include a copy of some (outdated) qt libraries at version 4.8.6.
    until these libs get omitted in the packaging process and the dependency get fixed to depend on system libs, you have to remove them manually after installing the deb...
    1. rm -Rf /opt/SEGGER/ozone/*/Lib/libQt*
