[SOLVED] [ARM] Running the JLinkGDBServer program on Raspberry Pi 3
  • [SOLVED] [ARM] Running the JLinkGDBServer program on Raspberry Pi 3
    I know that Segger does not OFFICIALLY support the Raspberry Pi's when getting their arm version of the JLink series software to work. However, I would be very appreciative if anyone can guide me.
    I am running Raspbian Jessie(from here: downloads.raspberrypi.org/raspbian_latest) with PIXEL, and I have been able to get the JLinkExe to see the JLink Edu I have attached to the USB Port.
    However, when I try to run JLinkGDBServer, it starts initializing but then stops with the error: "Connecting to target...Error: No CPU core or Target device has been selected".
    I am trying to run JLinkGDBServer on a Raspberry Pi 3.
    The USB end of the J-Link is connected to the Raspberrry Pi 3. The "JTAG" end (with 26 pins) is attached to a Raspberry Pi 2.
    I am using the JLink_Linux_V614h_arm.tgz version of the JLink software.
    Can someone please advise as to what I should do next?
    Thank you for your time,
    KRL
    The post was edited 1 time, last by KRL ().
  • Hi KRL,
    what command line parameters to you pass to the GDB Server?
    this will be fixed in the next version of the
    J-Link software & documentation pack
    J-Link software & documentation pack (beta)
  • Slightly different error from Ubuntu
    Hello, I just tried the latest (see the version below) JLinkGDBServer against Raspberry Pi 3. TDO is bouncing around in Logic Analyzer view (combination of 0x000000002 and 0x00000069A), so I think the GPIO pins have been remapped to JTAG (I wrote a little program to do this in U-Boot). Cortex-A53 should have the core debug registers no?
    parallels@ubuntu:~$ JLinkGDBServer -device cortex-a7
    SEGGER J-Link GDB Server V6.21a (beta) Command Line Version
    JLinkARM.dll V6.21a (DLL compiled Sep 29 2017 16:47:34)
    Command line: -device cortex-a7
    GDBInit file: none
    Terminal I/O port: 2333
    Accept remote connection: yes
    Generate logfile: off
    Verify download: off
    Init regs on start: off
    Silent mode: off
    Single run mode: off
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: cortex-a7
    Target interface: JTAG
    Target interface speed: 1000kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
    Hardware: V8.00
    S/N: 58009925
    Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    Checking target voltage...
    Target voltage: 3.31 V
    Listening on TCP/IP port 2331
    Connecting to target...ERROR: Cortex-A/R-JTAG (connect): Could not determine address of core debug registers. Incorrect CoreSight ROM table in device?
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    Shutting down...
    Please check power, connection and settings.
  • Hi Henry,
    this thread was about running the J-Link software on a Raspberry Pi, but not about using a Raspberry Pi as a target device.
    Thanks for opening a dedicated thread for this issue.
