DAP error while reading AHB-AP IDR
  • DAP error while reading AHB-AP IDR
    I am trying to debug some problems I am getting with recent versions of J-Link firmware. I use IAR and a J-Link Ultra+ to develop with a Silicon Labs EFR32 Mighty Gecko. I recently upgraded to the latest version of IAR, which upgraded the J-Link firmware and tools, and ever since then i get the error, "DAP error while reading AHB-AP IDR," after pausing, resetting, and running my program on my device. I would normally chalk this up to be an IAR error, but if I revert back to the older version of IAR that worked before I get the same problem. I've updated to the latest J-Link firmware from your site, 6.14f, I still get the same problem. I've tried to replicate the problem in J-Link commander, after connecting to the device I do go, hault, reset, go over and over, but I do not see the problem. I can replicate the problem with J-Flash if I flash the program, click "Start Application", click "Connect", click "Start Application" again, however if I try the same with an application that was compiled with the same IAR version but older J-Link I cannot replicate the problem.
    Any information or further debugging steps would be greatly appreciated.
    Thank You.
    thanks for your inquiry.
    Could you please provide us with two J-Link logfiles, one of a working and one of a non-working session?
    Log output can be enabled like as follows:
    • Open a connection to J-Link, e.g start J-Link Commander
    • In J-Link Control Panel: (Click the J-Link symbol located in the notification / tray area in order to open J-Link Control panel)
    • Open the tab "Settings"
    • Next to the field "Log file" check "Override" and click "..." in order to choose a log file path.
    This is also described in UM8001 Chapter 5 "Working with J-Link and J-Trace", Section 5.7 "J-Link control panel" .
  • Here are the log files you requested, j-link-not-working.log (new firmware reproduced with J-Flash), j-link-working.log (old firmware doing the same thing with J-Flash).
    I've tried a few more things since I posted originally:
    Upgraded to beta, 6.15c, this yields the same results as with 6.14f.
    Downgraded the dlls to 6.10n, J-Link firmware still from 6.15c, this fixes the problem.
    Thanks.
    • j-link.log.zip
      (4.63 kB, downloaded 681 times, last: )
    sorry, too many things an the ToDo-list...
    I will reserve a time slot for reproduction at the beginning of next week.
  • I got similar problem, is it J-link issue ?
    "Wed Jun 21, 2017 12:41:08: IAR Embedded Workbench 8.11.2 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\bin\armproc.dll)
    Wed Jun 21, 2017 12:41:08: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\config\flashloader\SiliconLaboratories\FlashGECKOP2.mac
    Wed Jun 21, 2017 12:41:08: Device "EFR32MG1BXXXF256" selected.
    Wed Jun 21, 2017 12:41:08: JLINK command: ProjectFile = D:\Projects\client\settings\app_CSL002-Debug.jlink, return = 0
    Wed Jun 21, 2017 12:41:08: Selecting SWD as current target interface.
    Wed Jun 21, 2017 12:41:08: JTAG speed is initially set to: 100 kHz
    Wed Jun 21, 2017 12:41:08: Found SW-DP with ID 0x2BA01477
    Wed Jun 21, 2017 12:41:09: Found SW-DP with ID 0x2BA01477
    Wed Jun 21, 2017 12:41:09: No AP preselected. Assuming that AP[0] is the AHB-AP
    Wed Jun 21, 2017 12:41:09: AP-IDR: 0x24770011, Type: AHB-AP
    Wed Jun 21, 2017 12:41:09: AHB-AP ROM: 0xE00FF000 (Base addr. of first ROM table)
    Wed Jun 21, 2017 12:41:09: Found Cortex-M4 r0p1, Little endian.
    Wed Jun 21, 2017 12:41:09: FPUnit: 6 code (BP) slots and 2 literal slots
    Wed Jun 21, 2017 12:41:09: CoreSight components:
    Wed Jun 21, 2017 12:41:09: ROMTbl[0] @ E00FF000
    Wed Jun 21, 2017 12:41:09: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS
    Wed Jun 21, 2017 12:41:09: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    Wed Jun 21, 2017 12:41:09: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    Wed Jun 21, 2017 12:41:09: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    Wed Jun 21, 2017 12:41:09: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 003BB923 TPIU-Lite
    Wed Jun 21, 2017 12:41:09: Warning: Could not set S_RESET_ST
    Wed Jun 21, 2017 12:41:09: Warning: CPU did not halt after reset.
    Wed Jun 21, 2017 12:41:09: Warning: CPU could not be halted
    Wed Jun 21, 2017 12:41:09: Core did not halt after reset, trying to disable WDT.
    Wed Jun 21, 2017 12:41:10: Warning: CPU did not halt after reset.
    Wed Jun 21, 2017 12:41:10: Warning: CPU could not be halted
    Wed Jun 21, 2017 12:41:10: Warning: Could not set S_RESET_ST
    Wed Jun 21, 2017 12:41:10: Found SW-DP with ID 0x2BA01477
    Wed Jun 21, 2017 12:41:10: Using pre-configured AP[0] as AHB-AP to communicate with core
    Wed Jun 21, 2017 12:41:10: Could not power-up system power domain.
    Wed Jun 21, 2017 12:41:11: SYSRESETREQ has confused core. Trying to reconnect and use VECTRESET.
    Wed Jun 21, 2017 12:41:11: Found SW-DP with ID 0x2BA01477
    Wed Jun 21, 2017 12:41:11: Using pre-configured AP[0] as AHB-AP to communicate with core
    Wed Jun 21, 2017 12:41:11: AP-IDR: 0x24770011, Type: AHB-AP
    Wed Jun 21, 2017 12:41:11: AHB-AP ROM: 0xE00FF000 (Base addr. of first ROM table)
    Wed Jun 21, 2017 12:41:11: Found Cortex-M4 r0p1, Little endian.
    Wed Jun 21, 2017 12:41:11: Warning: Failed to reset CPU. VECTRESET has confused core.
    Wed Jun 21, 2017 12:41:11: Warning: CPU did not halt after reset.
    Wed Jun 21, 2017 12:41:11: Warning: CPU could not be halted
    Wed Jun 21, 2017 12:41:11: Core did not halt after reset, trying to disable WDT.
    Wed Jun 21, 2017 12:41:11: Warning: CPU could not be halted Wed Jun 21, 2017 12:41:12: Warning: Could not set S_RESET_ST "
    I just gave it a try in J-Link Commander and unfortunately could not reproduce any issue.
    Could you please give J-Link Commander a try?
    J-Link commander is part of the J-Link software package, which is available free of charge here .
    • Start J-Link Commander (jlink.exe)
    • Type "connect" in order to start a debug session
    • Type in the target device name if asked (Or type "?" for a target selection Dialog)
    • Choose the correct target interface (JTAG/SWD/etc..)
    • Use a valid speed (Default: 4000kHz, try 100-500 if default does not work)
    • [JTAG only]JTAG conf can be default(most of the times)
    • You should now be successfully connected.
    If anything fails, could you please post a screenshot of the complete session?
    Could you also provide the following information:
    Do you use an eval board or custom hardware?
    Did this setup work in the past?
  • Here is my error log, appears in irregular intervals, tested with various speed, start from 35kHz.
    "SEGGER J-Link Commander V6.16c (Compiled Jun 16 2017 18:15:26)
    DLL version V6.16c, compiled Jun 16 2017 18:14:49
    Firmware: Silicon Labs J-Link Pro OB compiled Mar 9 2017 14:47:50
    Hardware version: V4.00
    S/N: 440055730
    IP-Addr: DHCP (no addr. received yet)
    VTref = 3.323V
    J-Link>connect
    Please specify device / core. : EFR32MG1BXXXF256
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    TIF>s
    Specify target interface speed [kHz]. : 4000 kHz
    Speed>
    Connecting to target via SWD
    Scanning APs, stopping at first AHB-AP found.
    AP[0] IDR: 0x24770011 (AHB-AP)
    CPUID reg: 0x410FC241. Implementer code: 0x41 (ARM)
    ****** Error: Connect: Communication error when trying to read IDR of AP[0].
    J-Link>"
    After the last update 6.16f it is impossible to unsecure the EZR32LG330F256.
    This issue is fixed in version 6.16j and later of the J-Link software & documentation pack.
    Does this error also occur when using v6.16j?
    If this issue does not occur, does it work for you, or are you experiencing other issues?
  • I have tested it today, in IAR debugger I often got error: Execution failure in flash loader
    I have checked it in jlink console, works correctly.
    Is there IAR or J-Link issue ?
    Here are my logs:
    "Thu Aug 03, 2017 13:53:38: IAR Embedded Workbench 8.11.2 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\bin\armproc.dll)
    Thu Aug 03, 2017 13:53:38: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\config\flashloader\SiliconLaboratories\FlashGECKOP2.mac
    Thu Aug 03, 2017 13:53:38: Device "EFR32MG1PXXXF256" selected.
    Thu Aug 03, 2017 13:53:38: JLINK command: ProjectFile = D:\Projekty\thread\sources\connector\settings\connector_EFR32MG1P-Debug.jlink, return = 0
    Thu Aug 03, 2017 13:53:38: JTAG speed is initially set to: 32 kHz
    Thu Aug 03, 2017 13:53:38: TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFFF1
    Thu Aug 03, 2017 13:53:38: Secured EFR32 device detected. This could cause problems during flash download.
    Thu Aug 03, 2017 13:53:38: Note: Unsecuring will trigger a mass erase of the internal flash.
    Thu Aug 03, 2017 13:53:38: Executing default behavior previously saved in the registry.
    Thu Aug 03, 2017 13:53:38: Device will be unsecured now.
    Thu Aug 03, 2017 13:53:38: Found SW-DP with ID 0x2BA01477
    Thu Aug 03, 2017 13:53:38: Scanning APs, stopping at first AHB-AP found.
    Thu Aug 03, 2017 13:53:38: AP[0] IDR: 0x24770011 (AHB-AP)
    Thu Aug 03, 2017 13:53:38: AHB-AP ROM: 0xE00FF000 (Base addr. of first ROM table)
    Thu Aug 03, 2017 13:53:38: CPUID reg: 0x410FC241. Implementer code: 0x41 (ARM)
    Thu Aug 03, 2017 13:53:38: Found Cortex-M4 r0p1, Little endian.
    Thu Aug 03, 2017 13:53:38: FPUnit: 6 code (BP) slots and 2 literal slots
    Thu Aug 03, 2017 13:53:38: CoreSight components:
    Thu Aug 03, 2017 13:53:38: ROMTbl[0] @ E00FF000
    Thu Aug 03, 2017 13:53:38: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS
    Thu Aug 03, 2017 13:53:38: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    Thu Aug 03, 2017 13:53:38: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    Thu Aug 03, 2017 13:53:38: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    Thu Aug 03, 2017 13:53:38: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 003BB923 TPIU-Lite
    Thu Aug 03, 2017 13:53:38: Setting AIRCR.SYSRESETREQ
    Thu Aug 03, 2017 13:53:38: Hardware reset with strategy 0 was performed
    Thu Aug 03, 2017 13:53:38: Initial reset was performed
    Thu Aug 03, 2017 13:53:38: Found 1 JTAG device, Total IRLen = 4:
    Thu Aug 03, 2017 13:53:38: Setting up GECKOP2 flash
    Thu Aug 03, 2017 13:53:38: 1024 bytes downloaded and verified (16.13 Kbytes/sec)
    Thu Aug 03, 2017 13:53:38: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\config\flashloader\SiliconLaboratories\FlashGECKOP2.out
    Thu Aug 03, 2017 13:53:38: Target reset
    Thu Aug 03, 2017 13:53:38: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\config\flashloader\SiliconLaboratories\FlashGECKOP2.mac
    Thu Aug 03, 2017 13:53:38: Execution failure in flash loader. Thu Aug 03, 2017 13:53:50: IAR Embedded Workbench 8.11.2 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\bin\armproc.dll) "
    "SEGGER J-Link Commander V6.16j (Compiled Jul 24 2017 18:42:58)
    DLL version V6.16j, compiled Jul 24 2017 18:42:23
    S/N: 440048406
    VTref = 3.329V
    J-Link>connect
    Please specify device / core. : EFR32MG1PXXXF256
    Device>
    J) JTAG (Default)
    S) SWD
    TIF>S
    Speed>
    Cortex-M4 identified.
    J-Link>"
    This is an error message by IAR.
    Could you please go to the project settings and make sure that the following box is unchecked?:
  • I have unchecked this option, debugger starts without error every time, but has often problem with stability during debug, I got disconnect or retry window.
    I come back this function, and put ticket do IAR support.
    Sounds good.
    Do you use low power-modes in your application?
    Some low power modes interfere or even disable the debug interface, which can cause J-Link to loose the connection.
  • Hi Niklas
    No, I don't have low power mode.
    It is better when chip is empty.
    In external tool Simplicity Commander I click "Unlock debug access" or "Erase chip" - I don't have debugger breakdown.
    Does this issue also occur with a simple application, like a loop which increments a counter?
    Could you please provide us with a screenshot of the error message?
    Could you please also provide us with the output of IAR of a session where the error ocurred?
  • Hi Niklas
    I will check on simple project.
    Today I have another error in IAR.
    Here is my screen: [img]https://ibb.co/etcoKv[/img] ibb.co/etcoKv
    If this error occurs, choose:
    - YES - I can't run the IAR debugger, despite many attempts, then I run jlink.exe connect to MCU without any problems, close jlink.exe, come back to IAR and debugger can start correctly.
    - NO - debugger starts, but after 1-2s I got message "Failed to get CPU status after 4 retries Retry?"
    I have checked on simple project, main with i++ counter, I don't have problems with stability.
    I have stability issue and error "Failed to get CPU status after 4 retries Retry?" when my code are using other MCU peryferials: gpio, uart and radio.
    The post was edited 1 time, last by tj7 ().
    Is it possible for you to isolate the code which is causing this issue?
