Jlink edu support for TI AM572x evaluation module
  • Thanks a lot Niklas.
    The problem for me has been relating/translating this text (with no reference to connect, write or key in the text)
    ## Function : Do a send-only JTAG IR/DR scan.
    Parameter : The route to JTAG shift state is 'shortest transition'.
    Parameter : The JTAG shift state is 'shift-dr'.
    Parameter : The JTAG destination state is 'pause-dr'.
    Parameter : The bit length of the command is '8'.
    Parameter : The send data value is '0x00000089'.
    Parameter : The actual receive data is 'discarded'.
    to this
    _ICEPICK_CONNECT_WRITE_KEY = 0x89;
    Anyways, as of now, the current status is, I am still unable to connect to the target. I am getting
    Entering custom J-Link script file!
    ICEPick IDCODE: 0x00000000
    Cannot read DAP IDCODE. Expected 0xXXXXX02F, read: 0x00000000
    TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
    cannot connect to target
    I think, I am unable to perform a TAP reset to make sure that icepick is the only device in the JTAG chain (to start with).
    The manual says (section: Initial Scan Chain Configuration), "The EMU0 and EMU1 pins should be pulled high at power-on-reset to configure the initial scan chain of the device to the TAP Router-only mode. In the TAP Router-only configuration, none of the secondary TAPs are selected. "
    But, the script seems to have writing JTAG sequence.
    // Perform a TAP reset to make sure that only the ICEPick is in the JTAG chain
    JTAG_Write(0x1F, 0, 6);
    So, I am assuming, that if we write this sequence then both EMU0 and EMU1 are pulled high. So, how do I get the "tms" and "tdi" values to write the JTAG sequence?
    Also, could you please let me know how to get/confirm the following values.
    _ICEPICK_IR_IDCODE = 0x04;
    _DAP_IR_IDCODE = 0xE;
    you are passing 0 to _ICEPick_AddTAP():
    1. _ICEPick_AddTAP(_ICEPICK_SDTR0);
    But you need to pass 0x0F:
    The TAP number is 15
  • Thank you. I just changed it. The result is the same as can be seen in the attachment.
    For reference, I also changed the following two lines from AHB-AP to APB_AP (according to TRM, page 7871)
    JLINK_CORESIGHT_AddAP(1, CORESIGHT_APB_AP); // AHB-AP to System Bus
    JLINK_CORESIGHT_IndexAHBAPToUse = 1; // Cortex-M: AP-Index of AHB-AP to use for communication with core. Cortex-A/R: AP-Index of AHB-AP that can be used for SEGGER RTT
    The post was edited 3 times, last by solidrepellent ().
    I am sorry, but this thread is way beyond "forum-support".
    We do not have the hardware here and this back and-forth (I suggest sth., you give it a try and report back) does not work out.
    I will ask in the next team meeting if we can order a board, but can not promise anything.
    I can also provide you with this "internal" script for the Ti AM335x, which is a Cortex-A8 (which is similar to a Cortex-A15).
    Maybe it helps.
    2. * SEGGER MICROCONTROLLER GmbH & Co KG *
    3. * Solutions for real time microcontroller applications *
    4. **********************************************************************
    5. * *
    6. * (c) 2011-2017 SEGGER Microcontroller GmbH & Co KG *
    7. * *
    8. * www.segger.com Support: support@segger.com *
    9. * *
    10. **********************************************************************
    11. ----------------------------------------------------------------------
    12. Purpose : J-Link script file for TI AM335x device.
    13. - Initializes ICEPick
    14. - Handles reset
    15. ---------------------------END-OF-HEADER------------------------------
    16. */
    17. /*********************************************************************
    18. *
    19. * Static code
    20. *
    21. **********************************************************************
    22. */
    23. /*********************************************************************
    24. *
    25. * _StoreSelDP
    26. */
    27. void _StoreSelDP(void) {
    28. JTAG_StoreIR(0xA); // DPACC command
    29. JTAG_StoreClocks(1);
    30. }
    31. /*********************************************************************
    32. *
    33. * _StoreSelAP
    34. */
    35. void _StoreSelAP(void) {
    36. JTAG_StoreIR(0xB); // APACC command
    37. JTAG_StoreClocks(1);
    38. }
    39. /*********************************************************************
    40. *
    41. * _StoreTriggerReadAPDPReg
    42. *
    43. * Function description
    44. * Triggers a read of an AP or DP register. Depends on the previous command (DPACC / APACC)
    45. */
    46. int _StoreTriggerReadAPDPReg(unsigned int RegIndex) {
    47. U32 v;
    48. int BitPos;
    49. //
    50. // Write 35 bits (32 bits data, 2 bits addr, 1 bit RnW)
    51. //
    52. v = 1; // 1 indicates read access
    53. v |= (RegIndex << 1);
    54. JLINK_JTAG_StartDR();
    55. BitPos = JLINK_JTAG_WriteDRCont(v, 3);
    56. v = 0;
    57. JLINK_JTAG_WriteDREnd(v, 32);
    58. JTAG_StoreClocks(8);
    59. return BitPos;
    60. }
    61. /*********************************************************************
    62. *
    63. * _StoreWriteAPDPReg
    64. *
    65. * Function description
    66. * Writes an AP or DP register. Depends on the previous command (DPACC / APACC)
    67. */
    68. int _StoreWriteAPDPReg(unsigned int RegIndex, U32 Data) {
    69. U32 v;
    70. int BitPos;
    71. //
    72. // Write 35 bits (32 bits data, 2 bits addr, 1 bit RnW)
    73. //
    74. v = 0; // 0 indicates write access
    75. v |= (RegIndex << 1);
    76. JLINK_JTAG_StartDR();
    77. BitPos = JLINK_JTAG_WriteDRCont(v, 3);
    78. v = Data;
    79. JLINK_JTAG_WriteDREnd(v, 32);
    80. JTAG_StoreClocks(8);
    81. return BitPos;
    82. }
    83. /*********************************************************************
    84. *
    85. * _InitIcePick
    86. *
    87. * Function description
    88. * Configures the ICEPick so that the CPU core also becomes
    89. * visible in the JTAG chain.
    90. */
    91. void _InitIcePick(void) {
    92. int BitPos;
    93. int v;
    94. int ICEPickIdCode;
    95. int DPIdCode;
    96. int Speed;
    97. Report("J-Link script: Init ICEPick");
    98. Speed = JTAG_Speed;
    99. JTAG_Speed = 100;
    100. JTAG_Reset(); // Perform TAP reset and J-Link JTAG auto-detection
    101. if (JTAG_TotalIRLen != 6) {
    102. Report("Can not find ICE-Pick (IRLen mismatch)");
    103. }
    104. JTAG_DRPre = 0;
    105. JTAG_DRPost = 0;
    106. JTAG_IRPre = 0;
    107. JTAG_IRPost = 0;
    108. JTAG_IRLen = 6;
    109. //
    110. // Check IDCODE of ICEPick (do not confuse with ICEPICKCODE or IDCODE of JTAG-DP)
    111. //
    112. JTAG_StoreIR(4); // IDCODE instruction for ICEPick device
    113. BitPos = JTAG_StoreDR(0x00000000, 32);
    114. ICEPickIdCode = JTAG_GetU32(BitPos);
    115. if ((ICEPickIdCode & 0x0F000FFF) != 0x0B00002F) { // highest nibble holds version information, so it can not be used for verification.
    116. MessageBox1("Can not find ICE-Pick (IDCODE mismatch). Expected 0x0B00002F, found: ", ICEPickIdCode);
    117. return 1;
    118. }
    119. //
    120. // Put the core in the JTAG chain
    121. //
    122. JTAG_StoreIR(7); // CONNECT
    123. JTAG_StoreDR(0x89, 8); // Put ICEPick module into connected state by writing the connect key. Bit 7 == 1 indicates write
    124. JTAG_StoreIR(2); // ROUTER (Accessing the mapped registers)
    125. v = 0
    126. | (0xAC << 24) // Write SDTAP12
    127. | (1 << 13) // Debug Connect
    128. | (1 << 8) // TAP select
    129. | (1 << 3) // Force active
    130. ;
    131. JTAG_StoreDR(v, 32); // Write SDTAP12
    132. JTAG_StoreDR(0xE0002008, 32);
    133. JTAG_StoreIR(0x3F); // BYPASS
    134. JTAG_WriteClocks(10);
    135. //
    136. // Configure JTAG chain, so J-Link knows to which device it has to "talk" to.
    137. // CPU core is in scan chain now, so we have to re-configure the JTAG chain settings.
    138. // The CPU core is device 0 (closest to TDO).
    139. //
    140. JTAG_IRPre=0;
    141. JTAG_DRPre=0;
    142. JTAG_IRPost=6;
    143. JTAG_DRPost=1;
    144. JTAG_IRLen=4;
    145. CPU=CORTEX_A8;
    146. JTAG_AllowTAPReset=0;
    147. //
    148. // Check core ID
    149. //
    150. JTAG_StoreIR(0xE); // Read JTAG-DP IDCODE register
    151. v = 0;
    152. BitPos = JTAG_StoreDR(v, 32); // Get ID
    153. DPIdCode = JTAG_GetU32(BitPos);
    154. if ((DPIdCode & 0x00000FFF) != 0x00000477) {
    155. Report("Can not find Cortex-A8 (IDCODE mismatch)");
    156. return 1;
    157. }
    158. //
    159. // Set JTAG Ids for all devices in the JTAG chain
    160. //
    161. JTAG_SetDeviceId(0, DPIdCode);
    162. JTAG_SetDeviceId(1, ICEPickIdCode);
    163. //
    164. // Set AP info for all APs in the device
    165. //
    166. CORESIGHT_AddAP(0, CORESIGHT_AHB_AP);
    167. CORESIGHT_AddAP(1, CORESIGHT_APB_AP);
    168. CORESIGHT_AddAP(2, CORESIGHT_JTAG_AP);
    169. CORESIGHT_CoreBaseAddr = 0x80001000;
    170. JTAG_WriteClocks(1); // Make sure that JTAG buffers are empty
    171. JTAG_Speed = Speed;
    172. return 0;
    173. }
    174. /*********************************************************************
    175. *
    176. * Public code, functions which are called by the DLL
    177. *
    178. **********************************************************************
    179. */
    180. /*********************************************************************
    181. *
    182. * ResetTarget
    183. */
    184. void ResetTarget(void) {
    185. int Speed;
    186. int BitPos;
    187. int Ctrl;
    188. int bcr0;
    189. int bcr1;
    190. int bvr0;
    191. int bvr1;
    192. int AddrBVR;
    193. int AddrBCR;
    194. int AddrDSCR;
    195. int AddrDRCR;
    196. U32 v;
    197. Report("J-Link script: Reset");
    198. Speed = JTAG_Speed;
    199. JTAG_Speed = 100;
    200. AddrBVR = 0x80001000 + (0x40 << 2);
    201. AddrBCR = 0x80001000 + (0x50 << 2);
    202. AddrDSCR = 0x80001000 + (0x22 << 2);
    203. AddrDRCR = 0x80001000 + (0x24 << 2);
    204. Ctrl = 0
    205. | (2 << 0) // AP-access size. Fixed to 2: 32-bit
    206. | (1 << 4) // Auto increment TAR after read/write access. Increment is NOT performed on access to banked data registers 0-3.
    207. | (1 << 31) // Enable software access to the Debug APB bus.
    208. ;
    209. _StoreSelDP();
    210. _StoreWriteAPDPReg(2, (1 << 24) | (0 << 4)); // Select AP[1] (APB-AP), bank 0
    211. _StoreSelAP();
    212. _StoreWriteAPDPReg(0, Ctrl);
    213. //
    214. // Remember settings for BP unit 0 and 1
    215. //
    216. _StoreWriteAPDPReg(1, AddrBVR);
    217. _StoreTriggerReadAPDPReg(3);
    218. BitPos = _StoreTriggerReadAPDPReg(3);
    219. bvr0 = JTAG_GetU32(BitPos + 3);
    220. BitPos = _StoreTriggerReadAPDPReg(3);
    221. bvr1 = JTAG_GetU32(BitPos + 3);
    222. _StoreWriteAPDPReg(1, AddrBCR);
    223. _StoreTriggerReadAPDPReg(3);
    224. BitPos = _StoreTriggerReadAPDPReg(3);
    225. bcr0 = JTAG_GetU32(BitPos + 3);
    226. BitPos = _StoreTriggerReadAPDPReg(3);
    227. bcr1 = JTAG_GetU32(BitPos + 3);
    228. //
    229. // Disable breakpoints on BP unit 0 and 1
    230. //
    231. _StoreWriteAPDPReg(1, AddrBCR);
    232. _StoreWriteAPDPReg(3, 0x00000000);
    233. _StoreWriteAPDPReg(3, 0x00000000);
    234. //
    235. // Set breakpoints
    236. // Break at 0x000240C0 which is a dead loop in the installer that is called if booting from NOR flash was selected but failed since NOR flash is empty
    237. // Break as soon as the CPU jumps to an address higher than 0x3FFFF. 0x0 - 0x20FFF is occupied by the bootloader at startup. RAM is beyond 0x3FFFF. When booting from NOR flash from CS0, the bootloader maps it to 0x08000000 and jumps to it.
    238. //
    239. _StoreWriteAPDPReg(1, AddrBVR);
    240. _StoreWriteAPDPReg(3, 0x00000000);
    241. _StoreWriteAPDPReg(3, 0x000200C0);
    242. //
    243. // Enable the breakpoints
    244. //
    245. _StoreWriteAPDPReg(1, AddrBCR);
    246. _StoreWriteAPDPReg(3, 7 | (0xF << 5) | (4 << 20) | (18 << 24));
    247. _StoreWriteAPDPReg(3, 7 | (0xF << 5) | (0 << 20));
    248. JTAG_WriteClocks(1); // Make sure that JTAG buffers are empty and breakpoint is set
    249. //
    250. // Setup JTAG config to "talk" to the ICEPick, so we can use the JTAG API functions
    251. //
    252. JTAG_DRPre = 1;
    253. JTAG_DRPost = 0;
    254. JTAG_IRPre = 4;
    255. JTAG_IRPost = 0;
    256. JTAG_IRLen = 6;
    257. //
    258. // Perform reset via ICEPick system control register, by setting the SysReset bit
    259. //
    260. JTAG_StoreIR(2); // Cmd: ROUTER
    261. v = 0x01000000; // Read SYS_CNTL
    262. JTAG_StoreDR(v, 32); // Send read register command
    263. BitPos = JTAG_StoreDR(v, 32); // Shift out register content
    264. v = JTAG_GetU32(BitPos);
    265. v &= 0x00FFFFFF;
    266. v |= 0x81000001; // Write SYS_CNTL and set SysReset bit
    267. JTAG_StoreDR(v, 32);
    268. JTAG_WriteClocks(10); // The reset needs some time to get active
    269. //
    270. // Setup JTAG config to "talk" to the Cortex-R4 again
    271. //
    272. JTAG_DRPre = 0;
    273. JTAG_DRPost = 1;
    274. JTAG_IRPre = 0;
    275. JTAG_IRPost = 6;
    276. JTAG_IRLen = 4;
    277. SYS_Sleep(200); // If device boots from NAND, make sure it has enough time to copy the second level bootloader and jump to it
    278. //
    279. // Check if CPU is halted. If not, halt it.
    280. // Select & setup APB-AP
    281. //
    282. _StoreSelDP();
    283. _StoreWriteAPDPReg(2, (1 << 24) | (0 << 4)); // Select AP[1], bank 0
    284. _StoreSelAP();
    285. _StoreWriteAPDPReg(0, Ctrl);
    286. //
    287. // Read DSCR to check if CPU is halted
    288. //
    289. _StoreWriteAPDPReg(1, AddrDSCR);
    290. _StoreTriggerReadAPDPReg(3);
    291. _StoreSelDP();
    292. BitPos = _StoreTriggerReadAPDPReg(3);
    293. v = JTAG_GetU32(BitPos + 3);
    294. _StoreSelAP();
    295. if ((v & 1) == 0) {
    296. //
    297. // If CPU did not halt after reset, halt it
    298. //
    299. Report("J-Link script: Core did not halt after reset. Halting core...");
    300. v |= (1 << 14);
    301. _StoreWriteAPDPReg(1, AddrDSCR); // Enable debug halt mode by writing the DSCR
    302. _StoreWriteAPDPReg(3, v);
    303. _StoreWriteAPDPReg(1, AddrDRCR); // Write DRCR to halt CPU
    304. _StoreWriteAPDPReg(3, 1);
    305. JTAG_WriteClocks(1);
    306. }
    307. //
    308. // Restore BP settings
    309. //
    310. _StoreWriteAPDPReg(1, AddrBVR);
    311. _StoreWriteAPDPReg(3, bvr0);
    312. _StoreWriteAPDPReg(3, bvr1);
    313. _StoreWriteAPDPReg(1, AddrBCR);
    314. _StoreWriteAPDPReg(3, bcr0);
    315. _StoreWriteAPDPReg(3, bcr1);
    316. _StoreSelDP();
    317. JTAG_WriteClocks(1);
    318. JTAG_Speed = Speed;
    319. }
    320. /*********************************************************************
    321. *
    322. * InitEMU
    323. */
    324. void InitEMU(void) {
    325. EMU_ETB_IsPresent = 0;
    326. }
    327. /*********************************************************************
    328. *
    329. * InitTarget
    330. */
    331. void InitTarget(void) {
    332. Report("TI AM335x (Cortex-A8 core) J-Link script");
    333. //
    334. // By performing a TRST reset, we make sure that only the ICEPick module is in the scan chain
    335. //
    336. EMU_JTAG_DisableHWTransmissions = 1; // We are not allowed to use the HW-units of the J-Link to transmit JTAG data
    337. JTAG_TRSTPin = 0;
    338. SYS_Sleep(50);
    339. JTAG_TRSTPin = 1;
    340. SYS_Sleep(50);
    341. JTAG_Write(0x1F, 0, 6);
    342. _InitIcePick();
    343. }
