[SOLVED] TI TMS570 attach to running target
  • [SOLVED] TI TMS570 attach to running target
    Working with a TMS570LS3137 powered safety ECU I have to connect to the running target in order to debug with safety outputs enabled.
    We use TI Code Composer Studio (CCS) 7, Jlink support installed. The Jlink version is 6.14b. The CCS Jlink drivers includes a Jlink script for the TMS570 MCU (TMS570.JLinkScript).
    The script overrides the Jlink DLL behaviour for InitTarget (setting up the TI IcePick ondevice JTAG controller and the JTAG chain) and ResetTarget (Reset via IcePick).
    Using Jlink with CCS 'out of the box' it will reset and halt (vector catch) the MCU when connecting (via the TargetReset() in the script).
    Thus no attach to a running target possible.
    I deactivated the ResetTarget routine in the script to omit the reset of the MCU during connect.
    Now I can connect to the running target however the CPU is halted after execution of the connect (InitTarget) routine whereas I would require it to continue running and set a breakpoint via Jlink.
    The behaviour is the same for the CCS Debugger and for Jlink commander (both executed with the patched JLinkScript).
    To start the target with the safe outputs enabled, you have to powercycle it: Thus i cannot start the target after having connected but have to attach to the running target.
    According to the Jlink Control Panel log I assume neither the CCS debugger nor the JLink commander send a "halt" explicitly during the connection process.
    Is there a way to attach to a running Cortex R4 MCU with Jlink and keep it running? What else could I check regarding this issue?
    Michael
  • Hi Michael,
    it is possible to connect to a running TMS570 target with the help of a J-Link script file.
    Please follow this wiki article for instructions: wiki.segger.com/TMS570Lx_series
    Does this work for you?
  • Hi Niklas,
    Yep, works like a charm.
    Thank you very much!
    Unfortunately I did not notice the nice wiki, could have saved us some time :)
    Interestingly, the command string used in the sample script is not documented in the JLink User Manual (UM08001 V6.14, sect. 5.12.1).
    Michael
  • Goal is to use "attach to running target" in TI Code Composer Studio (CCS) with the JLink integration of CCS.
    CCS allows for the specification of a JLinkScript file in target configuration (ccxml file). So I specified the JLinkScript allowing the attach to running target (no ECC Init).
    Now the CCS debugger connects to the running target, however, it halts the CPU after connecting.
    The log view of the JLink Control panel shows, that a JLINK_Halt() API call was invoked (see pic). This is not the case if I connect with Jlink commander (using said jlinkScript).
    Is it likely that the JLink adapter driver (JLINK2GTIAdapter.dvr) for CCS issues a connect and a halt when the CCS Debugger invokes connect target?
    In CCS debugger setup every checkbox regarding reset / halt target is unchecked...
    Michael
  • Hi Michael,
    in the current state of the plugin, J-Link allows executes a halt after a connect.
    According to the maintainer of the plugin, we cannot get the value of these checkboxes.
    We would probably need to add our own checkboxes and also find a way the inform the user that the other checkboxes are non-functional with J-Link.
    However, we need to schedule a time slot and investigate this, but this is currently not planned for the near future.
    Starting the CPU after a connect does not for your usecase?
  • Hi Niklas,
    thank you for the reply.
    Did I get this right: The CCS plugin for JLink executes the JLINK_Halt() after every connect?
    Ok then at least I know where it comes from :) I was quite sure it was the CSS Debugger.
    Starting the halted CPU after connect does not work:
    Observing our system in action relies on the TMS570 safety (main) CPU and the companion chip (watchdog) running synchronously - that is after a reset or power cycle.
    As soon as the main CPU is halted, the companion deactivates the outputs. Thus debugging strategy is to connect to the running system, set some breakpoints and wait until the CPU runs into a break point - then the outputs are disabled anyway. But up to then they are active thus allowing us to monitor the behaviour of the application.
    Is there a way to customize / patch the behaviour of the CCS JLINK plugin / driver?
    Michael
  • Hi Michael,
    Affirmative.
    Unfortunately, this is not possible.
    As an alternative for the moment:
    Do you want to give Ozone - The J-Link Debugger a try?
    Setup is simple: You just need to create a new project, select the TMS570 as a device, and then select the output file of CCS.
    Attaching can be done by selecting the dropdown menu next to the green on/off switch in the top left corner, and then select "Attach to Running Program".
    If you provide a .elf file to Ozone, Ozone will load the source code and source code line breakpoints and stepping are available.
    If you provide a file w/o debugging information (like .bin/.hex/.srec files), Ozone will show the disassembly.
    Please do not hesitate to ask if you have further questions regarding Ozone.
  • Hi Niklas,
    already evaluated Ozone in parallel to my attempts to make things work with CCS.
    I will try if I get attach to the running target (and subsequently set some break points while the CPU is running) work with Ozone.
    I assume invoking JLINK commands such as the "rnh" (reset no halt) command (jlink commander) is also much easier in Ozone as it would be in CCS..
    I am looking forward for your feedback on Ozone.
    Well, "rnh" is a J-Link Commander command, which is not directly connected to Ozone.
    But of course, the reset behavior of Ozone can be configured (via GUI and command line, in the GUI, the respective "Reset Mode" is called "Reset & Run".
    J-Link Command strings can be used in Ozone, and the various steps of the debugging procedure can be customized (before / after download, before / after target reset, before / after / during connect, etc...) if required, but also come with good default so it can be used out of the box w/o manual configuration.
