Can OS_TASK_EVENT be 64-bit unsigned on 32-bit ARM Cortex-M?
  • Can OS_TASK_EVENT be 64-bit unsigned on 32-bit ARM Cortex-M?
    We need more than 32 signals. Can OS_TASK_EVENT be safely defined as a 64-bit unsigned on 32-bit ARM Cortex-M, or does this violate the requirement for atomic types?
    If limited to 32 bits, is there a standard pattern for using perhaps a second event object and an 'Extension' signal sent to the Task Event?
    Thanks!
    Scott
  • Hi Scott,
    basically that should be doable since we already disable the interrupts while modifying the task event bit mask.
    You will need to define OS_TASK_EVENT as a 64 bit unsigned in e.g. your project settings while working with the embOS sources.
    But please contact us directly by email.
    That makes it easier to discuss the details.
    Til
