Eclipse Integration
  • Eclipse Integration
    I'm trying to run the debug in eclipse with the example 'hello world' program, but am running into issues. Namely, the message "No source available for "0xfffffffe"" is indicating issues. This memory location is where the program counter register says it is. Console dump listed below.
    SEGGER J-Link GDB Server V6.14a Command Line Version
    JLinkARM.dll V6.14a (DLL compiled Feb 27 2017 18:40:25)
    GDBInit file: none
    GDB Server Listening port: 2331
    SWO raw output listening port: 2332
    Terminal I/O port: 2333
    Accept remote connection: localhost only
    Generate logfile: off
    Verify download: on
    Init regs on start: on
    Silent mode: off
    Single run mode: on
    Target connection timeout: 0 ms
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: ATSAMD11D14AM
    Target interface: SWD
    Target interface speed: 1000kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link V9 compiled Dec 16 2016 15:34:10
    Hardware: V9.40
    S/N: 269401838
    OEM: SEGGER-EDU
    Feature(s): FlashBP, GDB
    Checking target voltage...
    Target voltage: 3.30 V
    Listening on TCP/IP port 2331
    Connecting to target...Connected to target
    Waiting for GDB connection...Connected to 127.0.0.1
    Reading all registers
    Read 4 bytes @ address 0x00000000 (Data = 0x20005000)
    Read 2 bytes @ address 0x00000000 (Data = 0x5000)
    Target interface speed set to 1000 kHz
    Resetting target
    Halting target CPU...
    ...Target halted (PC = 0x0000015C)
    R0 = 20004FE0, R1 = FFFFFFF9, R2 = 0000017F, R3 = C89B1FE5
    R4 = 3BA3DB7A, R5 = FD3A61CF, R6 = FAFD7DD7, R7 = 89F8A4FA
    R8 = 6F72F9B7, R9 = F13FDA0B, R10= 1B166FDA, R11= D1B19B3F
    R12= 83AF72DB, R13= 20005000, MSP= 20005000, PSP= E337D0E0
    R14(LR) = FFFFFFF9, R15(PC) = 0000015C
    XPSR 71000000, APSR 70000000, EPSR 01000000, IPSR 00000000
    CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    Read 4 bytes @ address 0x0000015C (Data = 0xF7FFB510)
    Read 2 bytes @ address 0x0000015C (Data = 0xB510)
    Select auto target interface speed (2000 kHz)
    Flash breakpoints enabled
    Semi-hosting enabled (Handle on BKPT)
    Semihosting I/O set to TELNET Client
    SWO disabled succesfully.
    SWO enabled succesfully.
    Downloading 430 bytes @ address 0x00000000 - Verified OK
    Downloading 40 bytes @ address 0x000001B0 - Verified OK
    Downloading 3399 bytes @ address 0x000001D8 - Verified OK
    Downloading 120 bytes @ address 0x00000F20 - Verified OK
    WARNING: CPU is running at very low speed (1327 kHz). Readback will be performed instead of CRC calculation.
    Comparing flash [....................] Done.
    Erasing flash [....................] Done.
    Programming flash [....................] Done.
    Verifying flash [....................] Done.
    Writing register (PC = 0x44000000)
    Read 4 bytes @ address 0x00000044 (Data = 0xB083B530)
    Resetting target
    R0 = 00000000, R1 = 41004004, R2 = 00001000, R3 = 00002000
    R4 = 20000380, R5 = FFFFFFFF, R6 = 00000000, R7 = 20000165
    R14(LR) = 2000015D, R15(PC) = 0000015C
    XPSR 41000000, APSR 40000000, EPSR 01000000, IPSR 00000000
    Starting target CPU...
    ...Target halted (DBGRQ, PC = 0xFFFFFFFE)
    WARNING: Failed to read memory @ address 0xFFFFFFFE
    WARNING: Failed to read memory @ address 0x20004FFC
    Reading 64 bytes @ address 0x20004FC0
    WARNING: Failed to read memory @ address 0x20004FC0
    WARNING: Failed to read memory @ address 0x20004FF8
    Seems like a reset occurred.
    Does the application use local resets or is there any chance that a hard fault was triggered?
  • My entire code right now is this:
    #include <stdio.h>
    int main(void) {
    int test = 0;
    while(1) test += 1;
    return 1;
    I suspect it's somewhere in the configuration, but don't see anything that stands out. I've attached screen shots of the configuration tabs for the Segger device. I'm using an Atmel ATSAMD11D14AM
  • Any suggestions??
    #include <stdio.h>
    int main(void) {
    int test = 0;
    while(1) test += 1;
    return 1;
