I am using STM32F429I-Discovery board and STemWin v5.32.
I am trying to use a JPEG image without converting it to c format. I am supposing that putting the file within the project folder will be enough in order to use the JPEG API.
The problem comes when, for example, I try to run the 2DGL_DrawJPEG example. When I compile it, I have an error related with the windows.h library and when i attache it to my project the error is that, as the compiler I am using (keil compiler) is not a GNU compiler, I cannot use this library.
What can I do to run the example?
Thanks!
Thanks!
