MMC_SPI - Reads but won't write
  • MMC_SPI - Reads but won't write
    This problem really has me stumped.
    I'm using emFile to interface a NAND flash and SD card on my own hardware. The NAND works perfectly, no issues.
    The SPI MMC/SD is another issue. If my application allowed, I could probably stream a MP3 off of the SD card, but I can't seem to write to it. Yes, I have checked that the card is not write-protected.
    This is what emFile is reporting:
    FS error: MMC_SPI: _WriteSectors: Data not accepted.
    FS error: MMC_SPI: _WriteSectors: Command not accepted.
    FS error: LOGBLOCK: Failed to write sector(s): 0x000080FD-0x000080FD to "mmc:0:".
    After this, the card is not accessible. For example, I can't do a directory listing. I have to remove the card, and re-insert it into the holder to gain access again.
    These errors were obtained when I ran the sample code that just writes a simple text file. The file creation is successful, but the file is empty.
    Some board specifics:
    STM32F303VE processor running at 72Mhz.
    (SPI3) SPI clock rate is 281khz as measured with a scope.
    emFile version V4.04a
    I have tried a couple different cards. Both had a FAT file system and when that didn't work, I formatted one of them to a FAT32 file system (didn't fix anything).
    Any direction would be helpful. I'm not sure where to look.
    Dave
  • Hello Dave,
    We are not aware of this behavior.
    The error messages suggest that the SPI data transfer is not working properly.
    I suggest you to check first if the SPI controller is correctly configured:
    - Data is sampled on the rising edge of the clock signal.
    - The clock signal is HIGH in idle state.
    You can find more information in the section "6.5.8.1.8 (*pfWrite)()" of the emFile manual.
    Marius
  • [SOLVED] but I can't explain it... very well.
    The code I used to send multi bytes of data to the MMC/SD card:
    1. /* Check flags to make sure SPI is idle */
    2. SPI_WAIT(SD_CARD_SPI);
    3. do {
    4. /* Send byte of data */
    5. SPI_SendData8(SD_CARD_SPI, *pData++);
    6. /* Wait for SPI complete send */
    7. SPI_WAIT(SD_CARD_SPI);
    8. /* Read data register */
    9. (void)SPI_CARD_SPI->DR;
    10. } while (--NumBytes);
    Looks reasonable, right? Except, remember that the data register is a 16-bits in the STM32F303 (and others).
    When I change the code to this:
    1. /* Read data register */
    2. SPI_ReceiveData8(SD_CARD_SPI);
    Everything works great. The call to function only reads 8-bits from the register and not 16 like I originally had. Again, it works but I can't really explain why reading the "throw away" data differently makes it work.
    Credit given to Tilen Majerle for his SPI code that I adapted.
    Thanks for the response. You were right... it was in the pfWrite code, but not how I imagined it would be.
    Dave
