[SOLVED] Global variables are missing in J-Scope
  • [SOLVED] Global variables are missing in J-Scope
    I've noticed that most of my global variables are missing in J-scope symbol selector. All my local variables in their corresponding C-file are showing however.
    I'm using VisualGDB with arm-eabi gcc compiler for a stm32f4 microcontroller.
    I've made sure that the optimization is completely off, i.e CFLAGS and CXXFLAGS set to -O0 in makefile settings.
    Don't know what else to check. Any help would be appreciated!
    which version of J-Scope do you use?
    Would it be possible to provide us with the .elf file so that we can reproduce the issue?
  • Hi, thanks for the fast response!
    I'm using version 5.10d. Attaching the .elf file for a simple example project that shows the problem. mems_visualGDB.zip
    What i discovered was that j-scope seems to be unable to see a global variable that is declared in main.h with the extern keyword, then this variable is defined in main.c as follows:
    In main.h
    extern uint32_t global_cnt;
    in main.c
    when opening j-scope the variable global_cnt simply does not show up. But maybe this is how it suppose to be?
    Mikael
  • Hi Mikael,
    thanks for the feedback.
    Good to hear that you are up and running!
