[SOLVED] PSoC 5LP extended memory programming
  • [SOLVED] PSoC 5LP extended memory programming
    I seem to be having a bit of trouble programming the extended memory areas of a Cypress CY8C5287AXI-LP095 MCU. As near as I can tell J-Link lacks built-in support for reprogramming the EEPROM, NVL and ECC areas.
    Fair enough. To rectify this I am looking into hacking together a CMSIS FLASH algorithm from the bootloader. Mostly to allow me to migrate away from the heinous Cypress Creator.
    Are there any sample implementations available for use as a starting point? Say, a no-op RAM reader/writer or some such.
    This MCU allows mapping in the 32 ECC bytes from each 256-byte FLASH row as general-purpose memory, which get written as single 288-byte rows but read back from a separate region at 0x48000000.
    Are there any clean ways of dealing with such discontiguously mapped memory areas? I am currently leaning towards forcing an initial full-chip erase, then programming each row twice.
    this can be done by using the Open Flashloader concept.
    Documentation can be found in the wiki: wiki.segger.com/Adding_Support_for_New_Devices
    and in UM8001 chapter "Open Flashloader", section "Editing/Extending an Existing Device".
    Template projects are available for Embedded Studio in the wiki, example XML files can be found in section "Example XML file" in the manual.
