How to use a Button, created by the GUI-Builder
  • How to use a Button, created by the GUI-Builder
    Hey everyone,
    Since a few days I am working with the STM32F746G-Discovery Board from ST.
    For my application, I would like to use the GUI Builder and create some Windows
    with Buttons and Images.
    I successfully implemented the GUI library from ST and created a nice starting
    screen with only one button.
    The problem is, I am struggling with the handling of touch events.
    The only thing I changed so far is, that inside of the WindowDLG.c file
    (created by the GUI Builder) I added one line of code.
    1. case
    2. WM_NOTIFICATION_RELEASED:
    3. //USER START (Optionally insert code for reacting on notification message)
    4. switch (Id) {
    5. case ID_BUTTON_0:
    6. WINDOW_SetBkColor(pMsg->hWin, GUI_BLUE); //<------------------------------------------
    7. break;
    8. }
    When I start the GUI and press the Button, nothing happens...
    Inside of my main.c I initialize the Touch Screen like this:
    1. static void BSP_Config(void) {
    2. /* Initializes the SDRAM device */
    3. BSP_SDRAM_Init();
    4. /* Initialize the Touch screen */
    5. BSP_TS_Init(480, 272);
    6. /* Enable the CRC Module */
    7. __CRC_CLK_ENABLE()
    8. ;
    9. }
    In addition to that, I call the following function every 50ms:
    1. void BSP_Pointer_Update(void) {
    2. uint8_t text[20] = "Hello World!\n\r";
    3. GUI_PID_STATE TS_State;
    4. static TS_StateTypeDef prev_state;
    5. TS_StateTypeDef ts;
    6. uint16_t xDiff, yDiff;
    7. BSP_TS_GetState(&ts);
    8. TS_State.Pressed = ts.touchDetected;
    9. xDiff = (prev_state.touchX > ts.touchX) ?
    10. (prev_state.touchX -
    11. ts.touchX) : (ts.touchX - prev_state.touchX);
    12. yDiff = (prev_state.touchY > ts.touchY) ?
    13. (prev_state.touchY -
    14. ts.touchY) : (ts.touchY - prev_state.touchY);
    15. if(prev_state.touchDetected > 0){
    16. HAL_UART_Transmit(&huart1, text, 20,
    17. 100);
    18. }
    19. if ((prev_state.touchDetected != ts.touchDetected) || (xDiff
    20. > 3)
    21. || (yDiff > 3)) {
    22. prev_state.touchDetected =
    23. ts.touchDetected;
    24. if ((ts.touchX != 0) &&
    25. (ts.touchY != 0)) {
    26. prev_state.touchX[0] =
    27. ts.touchX[0];
    28. prev_state.touchY[0] =
    29. ts.touchY[0];
    30. }
    31. GUI_TOUCH_StoreStateEx(&TS_State);
    32. }
    33. }
    I got this code from the Internet. I figured out, that I need this to upgrade
    the Touch status and the x and y position of the touch itself.
    I also send a String to my computer every time, I touch the screen.
    #### To sum it up:
    What do I need to change inside of the main so that the added line inside my
    WindowDLG.c file gets executed?
    (Do I need to do any additional configurations of the touchscreen? Do I need to
    put the created GUI somehow in the foreground? How do I need to change the BSP_Pointer_Update Function?)
    I really hope that somebody of you could help me. I cannot find any good
    examples or tutorials about this issue which explain the WHOLE problem.
    Kind regards
    Sören
  • Hi Sören,
    This is how we have implemented the touch into one of our STM32F746 Discovery project:
    2. *
    3. * PID_X_Exec
    4. */
    5. static void PID_X_Exec(void) {
    6. TS_StateTypeDef TS_State;
    7. static GUI_PID_STATE StatePID;
    8. static int IsTouched;
    9. BSP_TS_GetState(&TS_State);
    10. StatePID.Layer = 0;
    11. if (TS_State.touchDetected) {
    12. IsTouched = 1;
    13. StatePID.Pressed = 1;
    14. StatePID.x = (int)(TS_State.touchX[0]);
    15. StatePID.y = (int)(TS_State.touchY[0]);
    16. GUI_PID_StoreState(&StatePID);
    17. } else {
    18. if (IsTouched == 1) {
    19. IsTouched = 0;
    20. StatePID.Pressed = 0;
    21. GUI_PID_StoreState(&StatePID);
    22. }
    23. }
    24. }
    Important is that you generate up events, too, at the same position as the last down event. In our project we call this function from a dedicated touch task but it should be possible to call it from within a super loop. Once the touch input is properly passed to emWin the button should react as soon as it gets pressed.
    You can also take a look into our eval package. There is a PIDConf.c,located under Start/Setup/, which contains the function above. The package is for Embedded Studio but it should work as a reference when using a different tool chain.
    The package can be found here:
    segger.com/admin/uploads/evalB…I_IP_OS_MB_USB_160708.zip
