[SOLVED] Using JTAG on "Command Files"; Problems after Update
  • [SOLVED] Using JTAG on "Command Files"; Problems after Update
    Hey guys! So i recently made the update from 4.86 to 6.12g
    I used to flash my AT91SAM7X256 with SWD but I figured out, that I have to use JTAG now and im struggling with the correct
    syntax on the "commander file" (NOT the C-like script file) (reference to 3.2.3 in the "J-Link J-Trace User Guide").
    When i am using the j-link.exe commander manually, I neither get problems with the 4000khz default speed or the JTAGConf -1,-1
    Thats why I do not understand the failing start from my application.
    Here is my Application call with the exit after 10s of no response:
    1. Start arguments: ("-CommanderScript", "C:/Users/XXXXX/AppData/Roaming/XXXXX_ARM_Prog/XXXXX-PP_ARM.jlink")
    2. Starting Jlink
    3. ""
    4. exit= -1
    And this is my .jlink-File (command file):
    1. device = AT91SAM7X256
    2. if JTAG
    3. JTAGConf -1, -1
    4. speed adaptive
    5. r
    6. h
    7. loadbin Y:/Syslab/Projekte/TMCM-1060(siehe_auch_TMCM-1160)/Software/TMCM-1060Image_V448.bin, 0x100000
    8. r
    9. g
    10. qc
    Do you recognize anything wrong?
    Thanks for the help!
    could you please give a try to pass -JTAGConf as a command line option instead of specifying it in the command file?
    If the issue persists, could you please give a try to use the command file from the windows command line directly?
    good to hear that you are up and running!
