[SOLVED] SAMA5d2 Xplained
  • [SOLVED] SAMA5d2 Xplained
    Hello all,
    I'm trying to download & debug SW with my SAMA5d2 Xplained development kit.
    I did upgrade of J-Link EDBG firmware according to segger.com/jlink-edbg.html then:
    1] Mount BOOT_DIS jumper to avoid the device to run any valid code found on external non-volatile memories.
    2] Remove EDBG_DIS jumper to enable the EDBG device.
    3] First connect an USB cable to the A5-USB-A connector.
    4] Then connect an USB cable to the EDBG-USB connector.
    however, when I'm trying to debug I'm getting errors below ()whole log attached.
    Any Idea what could be wrong?
    SEGGER J-Link GDB Server V6.12d Command Line Version
    JLinkARM.dll V6.12d (DLL compiled Dec 21 2016 16:56:08)
    GDBInit file: none
    Terminal I/O port: 2333
    Generate logfile: off
    Verify download: on
    Init regs on start: on
    Silent mode: off
    Single run mode: on
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: Cortex-A5
    Target interface: SWD
    Target interface speed: 1000kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link EDBG compiled May 3 2016 15:18:23
    Hardware: V1.00
    S/N: 710399675
    Checking target voltage...
    Target voltage: 3.30 V
    Listening on TCP/IP port 2331
    Connecting to target...Connected to target
    Reading all registers
    Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    Target interface speed set to 1000 kHz
    ERROR: Cortex-A/R (connect): Could not unlock debug registers
    Resetting target
    Halting target CPU...
    WARNING: CPU could not be halted
    ERROR: Can not read register 9 (R15 (PC)) while CPU is running
    ...Target halted (PC = 0x00000000)
    ERROR: Can not read register 8 (CPSR) while CPU is running
    ERROR: Can not read register 34 (SPSR_UND) while CPU is running
    ERROR: Can not read register 36 (R14_UND) while CPU is running
    ERROR: Can not read register 35 (R13_UND) while CPU is running
    ERROR: Can not read register 31 (SPSR_IRQ) while CPU is running
    • Debug_log.txt
      (27.51 kB, downloaded 392 times, last: )
    thanks for the update and good to hear that you are up and running!
