Hi - I just got my JTrace Pro to replace my JLink Ultra+. My target is an LPC4350, which has an M4 and an M0 core. When connected via usb I'm able to connect and debug both cores simultaneously using Eclipse (GNU ARM Eclipse). When connected via ethernet Eclipse can connect to the M4 (first debug launched) but can't connect to the M0 (2nd debug launched). Is it possible to debug both cores via ethernet? If so, how?
[SOLVED/OR] LPC4350 multicore debugging via ethernet with JTrace Pro
Unfortunately, this is correct.
Currently, if you have two connections via USB, the J-Link software on pc-side does IPC/Locking between the two processes which have a connection on the host PC.
The IP implementation needs to take into account that the two connections may come from two different PCs, therefore IPC/Locking cannot be done by communication one host PC.
The IP implementation needs to be reworked in order to allow multiple connections, even if they come from the same host PC.
This is on our ToDo, but without a scheduled release date yet.
NiklasPlease read the forum rules before posting.
Or you can contact us via e-mail. -
Thank you for the info. Hoping it moves to the todo list sooner rather than later.
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
