Filter events sent by SysView
  • Filter events sent by SysView
    I have big overflows with segger sysview.
    Is it possible to modify RTT/SYSView configuration so as not to report OS_Use OS_Unuse events, so as to limit bandwith usage?
    The post was edited 1 time, last by user255 ().
    It is currently not possible to filter specific API events from being recorded.
    You can either record all events or none.
    How much data do you generate?
    With a reasonably large buffer (2 - 4 kByte) and and a higher target interface speed (4 - 16 MHz)
    SystemView should be able to handle most cases without overflows.
    Johannes
