Support for TI ARM compiler.
  • Support for TI ARM compiler.
    In order to get to work with the CC3200 I have had to add the following section at line 100 in "SEGGER_SYSVIEW_Conf.h" v2.40(a).
    Maybe you would like to add this support to the default distribution?
    Andre
    1. #elif defined(__TI_ARM__)
    2. #if (defined(__TI_ARM_V6M0__))
    3. #define SEGGER_SYSVIEW_CORE SEGGER_SYSVIEW_CORE_CM0
    4. #elif (defined(__TI_ARM_V7M3__) || defined(__TI_ARM_V7M4__))
    5. #define SEGGER_SYSVIEW_CORE SEGGER_SYSVIEW_CORE_CM3
    6. #endif
  • Hello Andre,
    Thanks for the code, we will add it to the SystemView sources as well.
    Johannes
