Error: CPU-TAP not found in JTAG chain
  • Error: CPU-TAP not found in JTAG chain
    Could you tell me what I am doing wrong, or what flaws I should look for? I read other threads where users were asked for IDCODE info, I copied those commands but got 0. Is that my problem (assuming I ran the commands correctly)?
    I have connected the J-link to a 20-pin ARM JTAG to 20-pin TI JTAG adapter, then to the target. The cables are a total of about 1 foot long, but I tried 1 khz. The EMU0 and EMU1 pins are floating on the TI adapter.
    SEGGER J-Link Commander V5.12e (Compiled Apr 29 2016 15:04:36)
    DLL version V5.12e, compiled Apr 29 2016 15:03:58
    Firmware: J-Link V9 compiled Mar 29 2016 18:46:37
    Hardware version: V9.30
    S/N: 269303908
    License(s): FlashBP, GDB
    OEM: SEGGER-EDU
    VTref = 3.283V
    J-Link>connect
    Please specify device / core. <Default>: ARM11
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    TIF>
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>1 khz
    Device "ARM11" selected.
    TotalIRLen = 12, IRPrint = 0x0AD1
    ****** Error: CPU-TAP not found in JTAG chain
    Can not connect to target.
    J-Link>wjc 6
    Command 0x6 (Unknown JTAG instruction) successfully written
    J-Link>wjd 0,36
    returns 0x0
    J-Link>wjc e
    Command 0xE (IDCODE) successfully written
    J-Link>wjd 0,36
    returns 0x0
    What target device do you have in your setup?
    Do you use custom hardware or an evaluation board?
    According to the output, you are using an older version of the J-Link software (V5.12e). Do you see similar behavior when using the latest version from our website (V6.12a)?
    segger.com/jlink-software.html
    Erik
  • I am targeting a custom Asic from TI in a production board. It has been end-of-lifed and there is no support or documentation.
    I believe it is ARM11. (It could also be ARM Cortex-M0, ARM Cortex-M0+, ARM Cortex-M1, SecurCore SC000)
    I will try the newer J-link software tonight, thank you.
  • No change with new software:
    SEGGER J-Link Commander V6.12a (Compiled Dec 2 2016 16:44:55)
    DLL version V6.12a, compiled Dec 2 2016 16:44:26
    Firmware: J-Link V9 compiled Dec 2 2016 15:35:20
    S/N: 269303908
    OEM: SEGGER-EDU
    VTref = 3.285V
    J-Link>connect
    Device>
    J) JTAG (Default)
    TIF>
    JTAGConf>
    Speed>5khz
    Cannot connect to target.
    The post was edited 1 time, last by skintigh ().
  • I believe it is ARM11. (It could also be ARM Cortex-M0, ARM Cortex-M0+, ARM Cortex-M1, SecurCore SC000)
    Without having this information, i do not really wonder that the connect fails because you have to at least select the correct core.
    Erik
  • Quick followup:
    Is it possible that you want to send simple JTAG sequences? If yes, you do not have to perform the "connect" in J-Link Commander. Especially if you do not have any information about your device. You can send the required JTAG sequences using the "wjraw" command which is available before "connect". Apart from this, we would recommend to rather use a J-Link script file to output JTAG sequences as they allow a more c like syntax.
    Erik
  • I have tried all 5 possible ARMv6 cores. Same results.
    I don't know anything about wjraw, do you have a guide or specific commands I should try?
    My primary goals are to dump the flash and memory. Using GDB would be also great. Anything you can tell me to go in that direction would be great.
    Thanks.
