Ozone - Relocate symbols
  • Ozone - Relocate symbols
    Using J-Link V612 and Ozone V2.22d.
    I've been able to load u-boot into DDR of i.MX6Q at base 0x17800000 address using Ozone. u-boot then relocates in RAM. Is there a way to have Ozone relocate the symbols? I can do it using GDB with symbol-file and add-symbol-file as described here - denx.de/wiki/DULG/DebuggingUBoot
    I'd prefer to continue debugging using Ozone after relocation.
    Daryl
    No, this is currently not possible. Ozone can only work with the symbol information which are part of the Elf file.
    We will add the option to use symbol files or similar to the wishlist for Ozone.
    Johannes
  • Thanks for the update.
    In case this helps anyone else, I was able to get the same result by rebuilding u-boot with the relocated address. For the i.MX6Q, I changed the CONFIG_SYS_TEXT_BASE in mx6_common.h from 0x17800000 to the relocated address and re-built it. I then loaded the new elf into Ozone to get the relocated symbols.
