This is with reference to following thread : "http://forum.segger.com/index.php?page=Thread&postID=12518&highlight=dhananjay#post12518"
As per the suggestion I tried selecting the CPU with (allow security) option (Freescale MKL17Z128xxx4 (allow security)) in project settings menu. It even worked at that time. But now it seems its not working. Strange! I doubt if I did something wrong earlier.
Now, When I select the CPU without security the the hex file works after programming. But if I select the CPU with security then the hex file fails to start after successful programming. What could be the reason? After programming if I click on “Start Application” in the J-Flash utility then it gives error (see attachment).
Also the device does not work after power-cycling. Please advice.
The post was edited 3 times, last by dpjoshi07@gmail.com ().
