[SOLVED] Cannot convert floating-point register value to non-floating point type.
  • [SOLVED] Cannot convert floating-point register value to non-floating point type.
    I'm trying to debug an arm cortex-m0 processor with a J-Link plus debugger from Ubuntu 16, but when I start the debugging session I get spammed with the following warning:
    "cannot convert floating-point register value to non-floating point type. Value has been optimized out".
    If I stop the debugging session(that hasn't really started), I'm not able to reconnect to the debugger since it states that I already have a running instance.
    I checked if a j-link task was running, and sure enough there was, but I was unable to kill it.
    Is there anyway to fix this?
    Note: I've tried debugging the same project on windows 10 with the same debugger and it works perfectly fine.
    this warning does not sound familiar.
    At first glance, I would guess that the message is not printed by the J-Link software.
    Could you please provide us with a J-Link log file?
  • The warning: "cannot convert floating-point register value to non-floating point type. Value has been optimized out" is from the console in Eclipse.
    If I start the GDB server from a terminal it keeps spamming the following in the console :
    " Starting target CPU...
    ...Breakpoint reached @ address 0x000022A4 "
    This does not stop until I stop the debugging in Eclipse.
    Furthermore I haven't placed any breakpoints in the code, the only one is a the temporary breakpoint at the start of main().
    SEGGER J-Link GDB Server V6.10i Command Line Version
    JLinkARM.dll V6.10i (DLL compiled Oct 25 2016 19:26:37)
    GDBInit file: none
    Terminal I/O port: 2333
    Accept remote connection: yes
    Generate logfile: off
    Verify download: off
    Init regs on start: off
    Silent mode: off
    Single run mode: off
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: atsamd21g18
    Target interface: SWD
    Target interface speed: 1000kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link V10 compiled Sep 1 2016 18:29:58
    Hardware: V10.10
    S/N: 600102037
    Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    Checking target voltage...
    Target voltage: 3.34 V
    Listening on TCP/IP port 2331
    Connecting to target...Connected to target
    Reading all registers
    Read 1 bytes @ address 0x0001064D (Data = 0xB5)
    Reading 64 bytes @ address 0x00010640
    Reading 8 bytes @ address 0x0001064D
    Reading 7 bytes @ address 0x0001064D
    Target interface speed set to 1000 kHz
    Resetting target
    Halting target CPU...
    ...Target halted (PC = 0x00001600)
    R0 = 00000000, R1 = A5A5A5A5, R2 = A5A5A5A5, R3 = 000075FD
    R4 = 200017D0, R5 = A5A5A5A5, R6 = 2000173C, R7 = 20001740
    R8 = 0001064D, R9 = 000119A5, R10= 20001810, R11= 2000176C
    R12= A5A5A5A5, R13= 20002048, MSP= 20002048, PSP= 20004EF0
    R14(LR) = 000107F1, R15(PC) = 00001600
    XPSR 61000000, APSR 60000000, EPSR 01000000, IPSR 00000000
    CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    Select auto target interface speed (2000 kHz)
    Flash breakpoints enabled
    Semi-hosting enabled (Handle on BKPT)
    Semihosting I/O set to TELNET Client
    SWO disabled succesfully.
    SWO enabled succesfully.
    Downloading 4096 bytes @ address 0x00002100
    Downloading 4096 bytes @ address 0x00003100
    Downloading 4096 bytes @ address 0x00004100
    Downloading 4096 bytes @ address 0x00005100
    Downloading 4096 bytes @ address 0x00006100
    Downloading 4096 bytes @ address 0x00007100
    Downloading 4096 bytes @ address 0x00008100
    Downloading 4096 bytes @ address 0x00009100
    Downloading 4096 bytes @ address 0x0000A100
    Downloading 4096 bytes @ address 0x0000B100
    Downloading 4096 bytes @ address 0x0000C100
    Downloading 4096 bytes @ address 0x0000D100
    Downloading 4096 bytes @ address 0x0000E100
    Downloading 4096 bytes @ address 0x0000F100
    Downloading 4096 bytes @ address 0x00010100
    Downloading 4096 bytes @ address 0x00011100
    Downloading 4096 bytes @ address 0x00012100
    Downloading 4096 bytes @ address 0x00013100
    Downloading 4096 bytes @ address 0x00014100
    Downloading 4096 bytes @ address 0x00015100
    Downloading 4096 bytes @ address 0x00016100
    Downloading 4096 bytes @ address 0x00017100
    Downloading 4096 bytes @ address 0x00018100
    Downloading 4096 bytes @ address 0x00019100
    Downloading 4096 bytes @ address 0x0001A100
    Downloading 4096 bytes @ address 0x0001B100
    Downloading 4096 bytes @ address 0x0001C100
    Downloading 4096 bytes @ address 0x0001D100
    Downloading 704 bytes @ address 0x0001E100
    Downloading 460 bytes @ address 0x0001E3C0
    WARNING: CPU is running at very low speed (1335 kHz). Readback will be performed instead of CRC calculation.
    Writing register (R8 = 0x95a90000)
    WARNING: Unsupported register (23)
    Read 1 bytes @ address 0x000022A4 (Data = 0xF0)
    Read 1 bytes @ address 0x000022A5 (Data = 0xB5)
    Resetting target
    R0 = 00000000, R1 = 41004004, R2 = 00000500, R3 = 00000A00
    R4 = 200003E0, R5 = FFFFFFFF, R6 = 00000080, R7 = 20000165
    R14(LR) = 2000015D, R15(PC) = 00001600
    XPSR 41000000, APSR 40000000, EPSR 01000000, IPSR 00000000
    Setting breakpoint @ address 0x000022A4, Size = 4, BPHandle = 0x0001
    Setting breakpoint @ address 0x000022A5, Size = 4, BPHandle = 0x0002
  • Not sure if you've resolved this. I was getting the same error. The fix for me was to change GDB executable to be "arm-none-eabi-gdb". This is on the Debugger tab of the debug configuration. This is my first post, but I'll try to attach a picture.
