Animation : filling a rectangle with an ellipse
  • Animation : filling a rectangle with an ellipse
    Hello.
    I need to play a little animation : I want to fill a rectangle at the bottom using an ellipse.
    Here is my code :
    GUI_SetColor(0);
    GUI_DrawRect(100,100,200,150);
    for (idx = 0; idx <100; idx++)
    GUI_AA_FillEllipse(100+50,150+20-idx,50,20);
    GUI_ClearRect(100,151,200,350);
    GUI_ClearRect(100,0,200,99);
    GUI_Delay(50);
    while(1);
    My Rectangle is filled , but I can see sometimes the ellipse before to be cleaned...
    I think I need to use 2 buffers or Memdev service but I don't know how I can use it.
    Is anybody can help me ?
    Thanks a lot in advance.
    You can enable automatic use of memory devices by calling WM_SetCreateFlags(WM_CF_MEMDEV). Call this function before GUI_Init() so the desktop window (WM_HBKWIN) can make use of the memory devices, too.
    Here is a simple sample which does almost what you want. I use a window for the drawing operation and an animation for calculating the y-position for the ellipse. The filling process starts on a button press.
    1. #include "DIALOG.h"
    2. #define ANIMATION_TIME 1000
    3. #define RADIUS_ELLIPSE 20
    4. static int _DoAnim;
    5. static int _AnimDir;
    6. static int _yPos;
    7. /*********************************************************************
    8. *
    9. * _AnimateWin
    10. */
    11. static void _AnimateWin(GUI_ANIM_INFO * pInfo, void * pVoid) {
    12. WM_HWIN hWin;
    13. int ySize;
    14. hWin = WM_GetFirstChild(WM_HBKWIN);
    15. ySize = WM_GetWindowSizeY(hWin) + RADIUS_ELLIPSE;
    16. //
    17. // Calculate the y-position for the ellipse
    18. //
    19. if (_AnimDir) {
    20. _yPos = ySize - ((ySize * pInfo->Pos) / GUI_ANIM_RANGE);
    21. } else {
    22. _yPos = (ySize * pInfo->Pos) / GUI_ANIM_RANGE;
    23. }
    24. switch (pInfo->State) {
    25. case GUI_ANIM_START:
    26. break;
    27. case GUI_ANIM_END:
    28. //
    29. // At the end of an animation we change the 'direction' for the next animation
    30. //
    31. _AnimDir = (_AnimDir) ? 0 : 1;
    32. break;
    33. }
    34. hWin = WM_GetFirstChild(WM_HBKWIN);
    35. WM_Invalidate(hWin);
    36. //
    37. // Avoid compiler warnings
    38. //
    39. GUI_USE_PARA(pVoid);
    40. }
    41. /*********************************************************************
    42. *
    43. * _cbWin
    44. */
    45. static void _cbWin(WM_MESSAGE * pMsg) {
    46. GUI_RECT Rect;
    47. switch (pMsg->MsgId) {
    48. case WM_PAINT:
    49. //
    50. // Set a back ground color and clear the window area with it.
    51. // It clears only the window area.
    52. //
    53. GUI_SetBkColor(GUI_BLACK);
    54. GUI_Clear();
    55. //
    56. // Receive client area of this window
    57. //
    58. WM_GetClientRect(&Rect);
    59. //
    60. // Set a foreground color and draw a frame and the ellipse at the calculated y-position.
    61. //
    62. GUI_SetColor(GUI_WHITE);
    63. GUI_DrawRectEx(&Rect);
    64. GUI_AA_FillEllipse(Rect.x1 / 2, Rect.y1 - _yPos + RADIUS_ELLIPSE, Rect.x1 / 2, RADIUS_ELLIPSE);
    65. //
    66. // The ellipse covers just a small area so we fill the rest with a restangle
    67. //
    68. GUI_FillRect(Rect.x0, Rect.y1 - _yPos + RADIUS_ELLIPSE, Rect.x1, Rect.y1);
    69. break;
    70. default:
    71. //
    72. // Any other messages are getting handled by the default callback
    73. //
    74. WM_DefaultProc(pMsg);
    75. break;
    76. }
    77. }
    78. /*********************************************************************
    79. *
    80. * _cbBk
    81. */
    82. static void _cbBk(WM_MESSAGE * pMsg) {
    83. int NCode;
    84. int Id;
    85. int xSize;
    86. int ySize;
    87. switch (pMsg->MsgId) {
    88. case WM_PAINT:
    89. GUI_Clear();
    90. break;
    91. case WM_NOTIFY_PARENT:
    92. Id = WM_GetId(pMsg->hWinSrc);
    93. NCode = pMsg->Data.v;
    94. switch(Id) {
    95. case GUI_ID_BUTTON0: // Notifications sent by 'Button'
    96. switch(NCode) {
    97. case WM_NOTIFICATION_CLICKED:
    98. break;
    99. case WM_NOTIFICATION_RELEASED:
    100. //
    101. // Set flag for starting animation
    102. //
    103. _DoAnim = 1;
    104. break;
    105. }
    106. break;
    107. }
    108. break;
    109. default:
    110. WM_DefaultProc(pMsg);
    111. break;
    112. }
    113. }
    114. /*********************************************************************
    115. *
    116. * Public code
    117. *
    118. **********************************************************************
    119. */
    120. /*********************************************************************
    121. *
    122. * MainTask()
    123. */
    124. void MainTask(void);
    125. void MainTask(void) {
    126. GUI_ANIM_HANDLE hAnim;
    127. WM_HWIN hWin;
    128. WM_HWIN hButton;
    129. //
    130. // Set create flag to use automatically memory devices, this is one way to avoid flickering.
    131. // Call this before GUI_Init() to set this flag for the desktop window, too. The desktop
    132. // window gets created in GUI_Init().
    133. //
    134. WM_SetCreateFlags(WM_CF_MEMDEV);
    135. GUI_Init();
    136. //
    137. // Set a callback for the desktop window. The callback handles the drawing of the window
    138. // and message send from the button.
    139. //
    140. WM_SetCallback(WM_HBKWIN, _cbBk);
    141. //
    142. // Create a simple window which does the drawing of the ellipse.
    143. //
    144. WM_CreateWindowAsChild(100, 100, 200, 150, WM_HBKWIN, WM_CF_SHOW, _cbWin, 0);
    145. //
    146. // Create a button as child of the desktop window. This button starts the animation.
    147. //
    148. hButton = BUTTON_CreateAsChild(10, 10, 60, 30, WM_HBKWIN, GUI_ID_BUTTON0, WM_CF_SHOW);
    149. BUTTON_SetText(hButton, "Start");
    150. while(1) {
    151. //
    152. // If the flag is set we create and start an animation
    153. //
    154. if (_DoAnim) {
    155. hAnim = GUI_ANIM_Create(ANIMATION_TIME, 10, 0, 0); // Create an animation which should last for the given time period.
    156. GUI_ANIM_AddItem(hAnim, 0, ANIMATION_TIME, ANIM_LINEAR, 0, _AnimateWin); // Add an animation item, this handles the calculation of an intensity.
    157. GUI_ANIM_Start(hAnim); // Start the animation
    158. while (GUI_ANIM_Exec(hAnim) == 0) { // As long as the animation lasts we call GUI_Delay(). This allows the
    159. GUI_Delay(5); // window manager to redraw the screen and other tasks can be escuted, too.
    160. }
    161. //
    162. // Once finished, delete animation and restore flag
    163. //
    164. GUI_ANIM_Delete(hAnim);
    165. _DoAnim = 0;
    166. } else {
    167. GUI_Delay(5);
    168. }
    169. }
    170. }
