Flasher portable - stand alone
  • Flasher portable - stand alone
    Hi Segger forum
    I have recently bought a Flasher Portable, which is to be used doing production runs. I have gotten it to work when connected to the computer and running the J-Flash software. But when trying to get it to work as a standalone it seems I am doing something wrong. In the log of the it says:
    ERROR: Failed to prepare for programming.
    Failed to execute RAMCode for RAM check!
    SN: 1 - Failed
    I have tried following the section in the J-Flasher manual "Setting up Flasher for stand-alone mode", and "Flasher Portable specifics", both with the same error in the log. Described briefly:
    Load .hex file into J-flash software, save config and data file, transfer config and data file to Flasher via MSD mode, Update INI file on device.
    The system I am trying to flash is a Cortex M0+ by silabs, custom board.
    Am i doing anything wrong? Why will it flash the unit through J-Flash and not as standalone?
    Hope you can help!
    Best regards, Tim
  • Hi Tim,
    could you please provide us with the exact target device name?
    In J-Flash could you please select File -> Download config & data file to Flasher instead of creating the files manually and see if it works this way?
  • Hi Niklas
    The device is an EFM32ZG110F32, on a custom board. I have previously used the dev-kit for the microcontroller for flashing the devices, which works fine.
    I get the same result by using the "Download config and data file to Flasher".
  • Thank you for the information.
    Is it possible that the EFM32ZG device is in a secured state?
    Differences between J-Flash (PC mode) and stand-alone mode: J-Flash performs an unsecure if the device is secured / a connection can not be established. In Stand-alone mode this special handling is not implemented right now.
    Easiest way to check:
    1) Erase the device using J-Flash
    2) Power-on-reset your hardware
    3) Program in stand-alone mode
    If the device is not secured and you still see any issues, we will give it a quick try here.
